Author Topic: Plastic.  (Read 1457 times)
Offline mongchops
Plastic.
« on: 11 December 2007, 20:30 »
How hard is the plastic trim on my mk2 to take off and put back on?
there is a bit under the front arch, just in front of the wheel that keeps flapping around and dragging on the road. it isn't there on the near side. the wheel arches seem a little too far from the body and not rigid enough, the rear bumper is a little out of line, the plastic between the front bumper and wheel arches could do with fitting a bit better.         :undecided:
Offline dabill
Re: Plastic.
« Reply #1 on: 12 December 2007, 11:10 »
arches are riveted on, so drill and then re-rivit them after, the side strips are a pull off jobby (be careful and take your time) and inner arch covers are bolted on. all fairly straight forward. just havea  good look about before you get annoyed and start raggin it off...
noble tuned - and still not fast enough!
Offline mongchops
Re: Plastic.
« Reply #2 on: 12 December 2007, 15:06 »
Thanks much. Think I might have a go this weekend   :undecided:
