Author Topic: Black plugs, running like poo  (Read 1251 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 09 December 2007, 21:45 »
Im still having troubles with my girlfriends 1.6 Driver. To drive it feels like its sometimes running on 3. I replaced the spark plugs, dizzy and rotor arm 2 weeks ago. I checked the plugs today and they are black (the probes of the plugs)  I have had a lot of very helpfull input from Rubjonny on this car and it looks like its the Pierburg carb causing these little flare ups! I checked the inlet flap on the airbox and it stays closed even when warm. I put a screw through the pipe to hold the flap at an angle to where warm air from the manifold can get to the carb and cold air can get in aswell, thought it would work..... i was wrong! On my little test drive for 1 mile all was ok, then had to do a 9 mile run a bit later and it started playing up again, jolting and a few backfires........... any ideas?
Re: Black plugs, running like poo
« Reply #1 on: 10 December 2007, 08:26 »
does sound like its running rich, next I'd be looking at the autochoke & inlet manifold heaters + their senders.  Did you say that you had checked the inlet manifold o-ring?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #2 on: 10 December 2007, 08:55 »
Hi John  :smiley:
Ive not checked the inlet manifold o-ring, will have a look now on your info about the Pierburg carb and see what that is!  Autochoke......could I put a manual one on it and loose the auto choke?
« Reply #3 on: 10 December 2007, 16:56 »
there were really nastly little bodge kits that would convert the auto choke to manual, but they aint easy to find!
