Author Topic: what size bulb  (Read 1354 times)
Offline 1688bran
what size bulb
« on: 09 December 2007, 18:01 »
     i just fitted HID light on my car ,so now i jus want to change the main beam bulb to match the HID light ,jus wanna know what bulb size is the main beam is ......
Offline richw911
Re: what size bulb
« Reply #1 on: 09 December 2007, 18:09 »
That one is an H1 bulb.  :wink:
Offline Ridg
  • TDI - Soot Happens!
Re: what size bulb
« Reply #2 on: 09 December 2007, 18:53 »
that depends actually, if you're installed OEM HID's then its an H7, if you've lodged after market illegal pony HID's into your existing cluster then its a H1
Offline 1688bran
Re: what size bulb
« Reply #3 on: 09 December 2007, 19:14 »
    well .... i just wanna change the bulb on the main beam  only to match the colour of my HID dip , so which size i should go for ..
Offline richw911
Re: what size bulb
« Reply #4 on: 09 December 2007, 19:41 »
Well if you have an after market HID setup and not original vw xenon headlights its H1. And as ridge says if you have original xenon headlights its H7.  :smiley:
« Last Edit: 09 December 2007, 19:42 by richw911 »
