Author Topic: Boost pipe  (Read 1547 times)
Offline richw911
Boost pipe
« on: 09 December 2007, 15:51 »
 Just fitted a boost gauge,Where do you tap the boost pipe in to? Can you use the top pipe on the dv?  :shocked:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Boost pipe
« Reply #1 on: 09 December 2007, 16:40 »
you can indeed mate, got mine tapped off there
Offline mike4golf
  • 1.8t
Re: Boost pipe
« Reply #2 on: 09 December 2007, 20:19 »
yep fitted mine on sat in same place
Offline leeroy20vt
  • h reg mk2 gti
Re: Boost pipe
« Reply #3 on: 09 December 2007, 21:23 »
goin to be doin mine this weekend have any 1 got any pics of were u put ur gauge cheers
Offline mike4golf
  • 1.8t
Re: Boost pipe
« Reply #4 on: 09 December 2007, 22:50 »
no pics m8 put mine in right top corner ov dash in pod above round vent n i think it looks well ,put a blue led bulb so matches dials
Offline richw911
Re: Boost pipe
« Reply #5 on: 09 December 2007, 23:36 »
Got mine mounted above the head unit:  :laugh:
Offline richw911
Re: Boost pipe
« Reply #6 on: 10 December 2007, 00:04 »
Tapped into the top pipe no probs. Now on idle is runnig about -19 psi is this correct??  :undecided: Does go up as you drive.....  Soz im new to boost gauges  :grin:
Offline GUY_GTI
Re: Boost pipe
« Reply #7 on: 10 December 2007, 13:33 »
yeah thats right mate it is running vacuum when it is idling so it is minus
watch the sump ask guy he went over a some toilet paper and it carcked!!!! :laugh: :laugh:
Offline leeroy20vt
  • h reg mk2 gti
Re: Boost pipe
« Reply #8 on: 10 December 2007, 13:41 »
cheers soz for the hijack i just ordered a pillar pod so should be ok
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Boost pipe
« Reply #9 on: 10 December 2007, 18:43 »
got mine sat on my steering column
