Author Topic: Conensation and dirt in headlamps Can they be removed to wipe clean?  (Read 1609 times)
Offline richardhammond
Conensation and dirt in headlamps glass.
 Can they be removed to wipe clean? If so how?
Offline monkeyalan
i don't think you can seperate the glass but if you take the light out you can fill it with detergent and water and clean them that way then rinse out and evaporate whats left with a hairdryer or on the radiator.
Offline nealey
i think you can seperate the glass but you have to get the glue hot enough to be able to pull them apart then you need some serious adhesive to stick them back on again
Offline 8vRicey
  • Silver Mettalic 8v GTI
Once cleaned, leave off the rubber cap from the back. It will stop the condensation.  :wink:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
The whole point of the rubber cap is to seal it and stop the conedensation, stop the moisture getting in..??
When you swil them try using filtered water or soemthing to that effect.. Stops it leaving water marks, I used my mums Brita jug to swill mine after cleaning  :grin:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
How do you remove them from the grill or can you not?
Offline vw-bob
are you asking can you remove the lights from the grill? if so then the lights arent actaully attached to the grill, they are attached to the slam pannel. you just remove the grill and then its 4 8mm screw head bolts holding the lights on
What the ajusting ones?
If so how do you set them back?
Offline vw-bob
the headlight is on a small frame, and the 4 bolt/screws hold the frame, which is attached to the light. it all comes off in one lump
Cool i will give it a go what should i use to clean them is normal widow clean with a bit of water good?
