Author Topic: Cam belt changed now getting a noise  (Read 1222 times)
Offline Chief1975
« on: 08 December 2007, 00:38 »
Hi All,
I had the cam-belt changed on my Mk4 Golf GTI today at a VW dealership, as I was driving home I noticed a new noise when I press the accelerator down. It only happens for a second or two when I first press the accelerator down then goes away. It doesn't happen when its out of gear or with the clutch engaged.
Could the belt be too tight or too loose?? any ideas? I am going to go back to the dealership but as I am not too savie on engines they could feed me any old bullsh*t!  :embarassed:
Chief
Offline richw911
Re: Cam belt changed now getting a noise
« Reply #1 on: 08 December 2007, 00:42 »
Well get back to them and see what thay say. Could be a loose plastic cover or a new fault a, Im sure thay wouldnt have fitted it wrong tbh.  :smiley:
Offline Chief1975
« Reply #2 on: 08 December 2007, 16:46 »
Picked it back-up from the dealership, noise has gone, they said they had to adjust / lubricate the tensioner as apparently it was too tight!?
Thanks
Chief
Offline richw911
« Reply #3 on: 08 December 2007, 16:50 »
Thanks
Chief
You cant trust anyone these days.... Least its sorted now mate  :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 08 December 2007, 17:10 »
belt bedding into the tensioner.. its normal :smiley: at least you know that means they've replaced all the right parts
