Author Topic: HELP FLOODED ROAD, DEAD CAR!  (Read 1361 times)
Offline OakeyDoak16v
« on: 06 December 2007, 19:49 »
Just giving the wife a lift to town and i came to a junction on the road that was severely flooded.
After much hesitation i decide to just go for it. Half way across i bottle it and reverse back. Driving off in different direction and 2 minutes later the car stutters and dies. It's now sitting in a park and ride on it's own :cry:
My fear is that i've got water into the engine and i'm thinking at the moment that it's got in through the exhaust when i reversed through the flood.
Any ideas what the worst case scenario is. Have i killed it? The engine turns over but doesn't spark up. Also when trying to restart the engine over and over i never got any smell of petrol as you sometimes would so not sure if fuel is getting sent along.
Any thoughts guys would be awesome as quite worried :sad:
Baz
Offline Organisys
  • Old and Slow...
Re: HELP FLOODED ROAD, DEAD CAR!
« Reply #1 on: 06 December 2007, 19:59 »
first step is to dry all the electrics. start with the distributor.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 06 December 2007, 20:02 »
wd40 time...it works wonders on getting rid of wet!
Offline Ade244
« Reply #3 on: 06 December 2007, 20:06 »
If it died 2 mins after backing out of the flood I would say its very unlikely you got water in through the exhaust.
The pressure on the exhaust keeps it out. Its only a problem if you stall in the flood isn't it?
Unless you went up to the lights it shouldn't get into the air inlet.
I would say it's electrical. Fuel pump, water in dizzy etc..
Not had my 16V long. Can you pull the plugs one at a time, ground them on the block and check for sparks
If it's not that then its fuel.
« Reply #4 on: 06 December 2007, 20:13 »
Thanks guy's will try drying everything out over the weekend and see how that goes :smiley:
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #5 on: 06 December 2007, 23:59 »
yes as above, it wont have killed it..turning over but not starting is deffo a spark issue :) it'll probs start first time when you go back to it
Offline dabill
« Reply #6 on: 07 December 2007, 09:36 »
when we had floods in sheffield, mates polo got nearly fully submerged. 2 days later, he turned the key, pop pop and its running fine. let it dry out and you'll be fine.
noble tuned - and still not fast enough!
Offline logix42p
« Reply #7 on: 07 December 2007, 09:40 »
Like others said just try and let it dry as i flooded a car and stalled and got water in the engine and the engine seized completely (hydrostatic lock) so as yours is turning over then this isnt the case.
Offline capoot
  • Mk1 Skoda Octavia VRS
« Reply #8 on: 07 December 2007, 09:43 »
Where in cheshire were you?!
« Reply #9 on: 08 December 2007, 00:47 »
In Sunny Chester, I think your from around here too aren't you?
By the way, went back to the car this morning and fired up first time so great news. Certainly be more careful though next time i'm faced with flooded roads :rolleyes:
Still gonna check the distributor etc on Sunday for damp.
Cheers eveybody for your comments.  :wink:
