Author Topic: How long to fit a radiator?  (Read 2582 times)
Offline Dec
« on: 05 December 2007, 20:17 »
Ok my dad was an exmechanic so is pretty handy but how long would it take to take off the old radiator, fit a new one and put coolant in? Is that all we have to do? Is it a full days job and is there alot of taking apart to do?
« Last Edit: 05 December 2007, 20:20 by Dec MK2 »
Offline dubslug
Re: How long to fit a radiator?
« Reply #1 on: 05 December 2007, 20:25 »
rad is easy mate....
u have to disconnect the 3 hoses to the rad....
undo the 2 10mm bolts on slam panel
remove the wiring for rad switch
remove the fan switch wiring
the rads now ready to come out....
once out undo the 4 bols holding the fan housing on
bolt fan housing onto new rad and then re fit everything above
1992 pearl grey 8v
Offline dubslug
« Reply #2 on: 05 December 2007, 20:26 »
oh and add fluids after too
1992 pearl grey 8v
Offline Dec
« Reply #3 on: 05 December 2007, 20:28 »
Cheers mate :smiley: doesnt sound too bad. Not sure how bad my rads leaking yet as i havent used my car at all yet but only 2 days now :shocked: so better sort it out if it is gonna cause a problem :sad:
Have changed the coolant before so know how to do that :smiley: going to replace all of the clips holding the hoses on to jubilee clips too to make them a bit more secure :smiley:
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #4 on: 05 December 2007, 20:54 »
get a haynes.. will save you loadsa hassle, and wasted time loggin on the net, typing a problem, waitin for a reply lol
Offline dubslug
« Reply #5 on: 05 December 2007, 21:08 »
haynes book of lies lol....
best to ask too id say
1992 pearl grey 8v
Offline Dec
« Reply #6 on: 05 December 2007, 21:12 »
Got a haynes and i leave my pc on all the time anyway (dont ask the elecy bill :laugh:) and was bored anywho :embarassed:
They haynes is ok, and i was fairly sure it was simple but i still like to ask :embarassed:
EDIT: just looked in the haynes and it says to disconnect the batterys negative lead. Why do you have to do that?
« Last Edit: 05 December 2007, 21:15 by Dec MK2 »
Offline russ-vdub
« Reply #7 on: 05 December 2007, 21:15 »
furry muff.. i pretty much learnt all i know from the haynes and ive already done an engine swap and only been drivin for 2 years and tinkering with engines for 6 months lol
Offline Horney
« Reply #8 on: 05 December 2007, 21:18 »
It's just good practice whn working on any vehicle. Saves you shorting something by mistake and blowing loads of fuses or worse!
A rad change should take no more than an hour.
Nick
Offline russ-vdub
« Reply #9 on: 05 December 2007, 21:21 »
nice new sig nick... i see the sign edit on the right..sly lol.. sorry bit off topic but i'd always disconnect the battery for the reasons nick said
