Author Topic: MK2 8V Brakes Issue  (Read 1244 times)
Offline JB G60
MK2 8V Brakes Issue
« on: 05 December 2007, 17:26 »
Had my discs and pads all round done a few thousand miles ago but recently some times when I press the brakes the pedal goes straight to the floor, it still brakes a bit but is still very worrying. Most of the time it would be spot on braking top notch. Its an '88 8v any ideas what it could be?
Offline DogDay
Re: MK2 8V Brakes Issue
« Reply #1 on: 05 December 2007, 17:55 »
Bleed the brakes 1st - see if it makes a difference - after that i would be thinking check the rubber brake lines & master cylinder
IB :cool:
Bow Chikka Wow Wow
Offline Spawn_of_Satan_666
« Reply #2 on: 05 December 2007, 20:31 »
Sounds like you've got air in the system somewhere. Like the above note check for leaks and bleed the system.
164 bhp Get in there!!<br /><br />
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #3 on: 05 December 2007, 21:04 »
deffo master cylinder.. if works most of the time then sometimes straight to the floor then the seals have gone inside the m/s..
Offline russ-vdub
« Reply #4 on: 05 December 2007, 21:05 »
also under what conditions does it not work? under hard braking? also id get it sorted ASAP..dnt wana crash and mash your mk2 and get a claim
Offline JB G60
« Reply #5 on: 05 December 2007, 22:03 »
Doesn't seem to happen under heavy braking strangely enough! Just every now and again while driving normally. Will bleed the system first if it don't do it - on to the master cylinder.
Thanks
Offline Village Idiots
« Reply #6 on: 05 December 2007, 22:24 »
You can get this if one of the brakes is rubbing on and getting the calipers too hot...it boils the fluid.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #7 on: 05 December 2007, 22:24 »
I would go for the master cylinder first. A repair kit does not cost much and the job is not difficult. Either way, you will need to bleed the brakes. Do it soon. During winter, you need good anchors.
Offline russ-vdub
« Reply #8 on: 05 December 2007, 22:34 »
a repair kit? is that for the m/s.. where would you get one?
