Author Topic: Fitting Speakers  (Read 2506 times)
Offline winn69
Fitting Speakers
« on: 05 December 2007, 15:42 »
Hi Guys
Just wondering if anyone can help...
I have a mk4 Golf GTI Turbo. 4 door.
I am wanting to fit some 6*9 speakers into my back parcel shelf.  In past cars this has been easy but seems a bit tricky with the golf as the 4 speakers it already has are in the doors.
I either want to split the wires from the rear doors or where the head unit starts.
Rear Doors - does anyone know if the speaker wires run accross the floor or the roof?
Head unit - or am i better off taking this out and splitting the wires here and bring them to the back?
Anyone have any advice on the best way to do this?
Also if I was to replace the head unit with an mp3 player would this be ok to do? Would I take out the radio or the CD inset bit above?
Any help appreciated
Thanks
Offline Ashmond
  • Money, b!tches And Boost
Re: Fitting Speakers
« Reply #1 on: 05 December 2007, 16:09 »
To be honest mate if you want to run 6x9's I would get an amp, have a look on caraudiosecurity.com they got ones for £30. I would also check that you do actually have speakers in the back pods because I actually didnt have any in there. If thats the case then you can have the 6x9's from the stereo but they will be really lame in comparison to if you get an amp. Most headunits are 4x50watts (not sure if the standard vw ones are the same) so what I did was run my 4 pod speakers off the headunit and amp the 6x9's.
Offline winn69
« Reply #2 on: 05 December 2007, 16:27 »
hi mate
yeah i deffo do have the speakers in there i had the pannells off the doors.
i do have an amp.  its prob easyer to take out head unit fit amp and run wires to 6*9s?
is there any probs with taking out the head unit?
Offline Ashmond
« Reply #3 on: 05 December 2007, 16:38 »
run your 6x9's through your amp, and amp the pod speakers off the 4x50watt outputs.
As I said in a previous post, the headunit is a tosser to get back in, just got to wiggle it about, dont be afraid to give it a proper push in though  :wink:
Offline winn69
« Reply #4 on: 05 December 2007, 16:42 »
thanks
last question...
will i be able to fit amp into standard head unit or will i have to fit another cd player?
also
if i am putting in a cd player do i take out the cd insert section or the radio section?
Offline Ashmond
« Reply #5 on: 05 December 2007, 17:08 »
amp wont go into a standard unit I dont believe, I had a tape deck and that was it with mine so im not sure about the cd ones. You need aux inputs to run your phono's to and my standard unit didnt have them
