Author Topic: Remote battery..  (Read 1816 times)
Offline richw911
Remote battery..
« on: 04 December 2007, 18:31 »
I need to change the batterys in my key fob remotes. Now what battery do i need? If i take the battery out will it lose its immobiliser code? Should i take it to the dealers and get robbed blind  :grin: Cheers Rich.
Offline MaXXeH
  • Golf MK5 GTI
Re: Remote battery..
« Reply #1 on: 04 December 2007, 18:39 »
i have changed the batt on mine and it worked fine after?
Offline Ridg
  • TDI - Soot Happens!
« Reply #2 on: 04 December 2007, 18:56 »
AFAIK the immobilizers is done on a chip so wont be lost even if you're really slow changing the bat, the bats you need as CR2032
vag parts actually sell genuine ones at quite a good price, you can get CR2032's pretty much everywhere though.
Offline Stronz
  • Sold!
« Reply #3 on: 04 December 2007, 20:48 »
I changed min with no problem. Think the battery was soemthing like 50p in Maplins.
Offline richw911
« Reply #4 on: 04 December 2007, 21:58 »
I just opend the batt case up and ive got two batterys, with the number "cr 1620" thay are panasonic ones. Do i need two cr 1620 then?? Not CR2032??
Offline Ridg
« Reply #5 on: 04 December 2007, 22:04 »
well the CR1620 is 3v and so is the CR2032 is 3v also so 2 CR1620's would give you 6v
every key fob i've seen has only ever had a CR2032 in so sounds like someone has bodged that key
Offline richw911
« Reply #6 on: 04 December 2007, 22:10 »
Ive just opend the spare key its the same two cr1620. Mine are the old two button style keys tho  :undecided:
Offline richw911
« Reply #7 on: 04 December 2007, 22:39 »
Ah sorted just found this:
http://www.clubb5.com/information/replacingbattery.shtml
Its because mines the old type key with the two buttons. 2 CR1620 it is then. Thanks for your help guys  :smiley:
