Author Topic: Mk4 Golf speedo keeps stopping every journey.  (Read 1525 times)
Offline powers9568
« on: 04 December 2007, 16:24 »
Could anybody help with this problem I have with my mk4 Golf which is after about 6-10 miles the speedo just stops working.
Offline Gates79
Re: Mk4 Golf speedo keeps stopping every journey.
« Reply #1 on: 02 February 2008, 13:44 »
I had a similar problem but my speedo didnt work at all and the fuel gauge would go up and down when cornering. I replaced the speed sensor on the gearbox but nothing changed. I then started to check the wiring and found that it had corroded just underneath the battery tray where it joins the main wiring loom so i cut the bad stuff away and rejoined them with small crimp terminals and taped it all back up and everything works fine now. Hope this helps
