Author Topic: Electric Windows  (Read 3229 times)
Offline GTI16vGaz
  • New car will be displayed soon.
Electric Windows
« on: 18 March 2004, 13:09 »
Hellloo, wondering if any1 can help.
I have electric windows in my GOLF GTI16v but the drivers side does not work it stopped working the other day the passenger side is fine so first of all i swapped swtiches still no movement so i decided to take the door card off and have a look but i couldn't work anything out, i tried to pull the connector apart that connects the Electric Motor to the swtich the connection was really hard so i ended up leaving it!  ???
Is there a fuse per for each side, may be i've blown a fuse, not sure??
or could the motor have blown and i need a new 1.
If any1 could help that would be great  ;D
Thanks
Gaz ;)
Offline Dizzie
  • Make friends with your fast
Re:Electric Windows
« Reply #1 on: 18 March 2004, 13:17 »
there's only 1 fuse for the lot. sounds like either the motor has gone or there's something jammed and stopping it moving. at least it's up. mine will go down sometimes and no come back up  >:(
Offline GTI16vGaz
Re:Electric Windows
« Reply #2 on: 18 March 2004, 13:20 »
Thanks for that mate.. I think i'm gone try and buy a new motor, do you know any1 that sells them?
Thanks  ;)
Offline GTI16vGaz
Re:Electric Windows
« Reply #3 on: 18 March 2004, 13:23 »
Also the motor was getting warm when trying the swtich, i wonder if its stuck.
If the motor had blown it wouldn't get hot or would it?
Blue MK2
Re:Electric Windows
« Reply #4 on: 18 March 2004, 14:47 »
yep, must of got water in it. you could get away with taping it and WD40'ing the f**kker :D
are any wires cut from the door corner?
« Last Edit: 18 March 2004, 14:48 by Blue MK2 »
Offline GTI16vGaz
Re:Electric Windows
« Reply #5 on: 18 March 2004, 19:33 »
No Wires are cut from what i can see! i bet the mortor has gone.
Offline JMallows
Re:Electric Windows
« Reply #6 on: 18 March 2004, 19:52 »
Motors like that rarely break. If you cant see any other cause of the problem and are adamant that its the motoe knackered, try one of these as i bet a new motor is V expensive!!
  • Swap the motor for the passenger side to test it.
  • Go to a scrapyard and say to the bloke, i'm not sure if its a wiring problem, can i just test the motor before i tske it away. If you dont deprive him of his time, he shouldn't object, its in his best interest to be co operative!!
With the first, i dont have electric windows, so i dont know how easy this is. With the second, i've done it before, if he's nice enough, you should be able to try, or just try it, then take it back saying it dont work...?
A clever person solves a problem. A wise person avoids it.
Veedubgt18v
Re:Electric Windows
« Reply #7 on: 19 March 2004, 10:24 »
or just nick it  ;)
Offline Gambit
Re:Electric Windows
« Reply #8 on: 19 March 2004, 11:32 »
get a multi meter to test there is power getting to the motor
if there is, and none of the wire cables attached to the window mechanism are snapped then do as Dizzy suggests and tap it with a hammer while you operate the swtiches
Offline Dannyd
  • LOOK AT THAT VALVER GO!
Re:Electric Windows
« Reply #9 on: 20 March 2004, 17:52 »
i've had the same problem and its a bit strange to fix ???
basically the bracket that holds the window on the runner jamms the wire into the wheel at the top of the runner. now for the strange part (fixing-it)
take the bolts out on the runner and leave them out
it works for me and has never stuck since (weird)
unless it is missing a stop or rubber thing  any idea's?
wacked up on scuby snacks!
