Author Topic: 8v and 16v springs  (Read 1373 times)
Offline Philpy
8v and 16v springs
« on: 03 December 2007, 14:58 »
Ive noticed after market springs are always listed differently for the 2 different engines..... Ive just bought some 8v Eibachs, Any problem fitting them to my 16v?
Whats the difference?
Offline Horney
Re: 8v and 16v springs
« Reply #1 on: 03 December 2007, 15:01 »
16v springs are 10mm lower then 8v springs which are 10mm lower than standard springs!
Nick
Offline Mew
« Reply #2 on: 03 December 2007, 15:01 »
Well i had 16v eibachs (didn't realise at first) on my 8v and the front didn't drop as much as i expected tbh. I imagine yours will drop a little more than normal at the front, nothing drastic though!
Offline Horney
« Reply #3 on: 03 December 2007, 15:04 »
He's going the other way though bud so he's going increase his front ride height by 10mm.
Nick
Offline Mew
« Reply #4 on: 03 December 2007, 15:15 »
I was thinking more in terms of weight, as i thought that an 8v and a 16v lowered on respective Eibach springs end up sitting at the same height. I may well be wrong though!
Offline Horney
« Reply #5 on: 03 December 2007, 15:17 »
I dunno about that I thought the engines weighed about the same? What do I know though I've only ever had 8v's!
Nick
Offline Mew
« Reply #6 on: 03 December 2007, 15:25 »
Volkswagen Golf Mk2 (19E) From :08/83>12/92, Will Fit: 1.0, 1.3, 1.6, 1.8, 1.8 GTI, 1.8 GTI G60
Eibach Pro-Kit Springs
ONLY £132.14 (inc VAT)
Lowers Front: 30-40 mm & Rear: 30-35 mm
Product code: 8502-140
Volkswagen Golf Mk2 (19E) From :08/83>12/92, Will Fit: 1.8 16V, 1.6 D, 1.6 TD
Lowers Front: 20 mm & Rear: 20 mm
Product code: 8509-140
Deffo different springs as they have different part numbers, and if the 8v lower by 30mm and the valver springs lower by 20mm after the 10mm drop on the 8v, then they would sit at the same height. Or am i working that out wrong!?  :grin:
They will still fit your shocks perfectly fine and you won't have any problems fitting them, not too sure the springs will handle in the way they are meant to though?  :undecided:
