Author Topic: Dropping window  (Read 850 times)
Offline T_J_G
Dropping window
« on: 02 December 2007, 18:58 »
Drops about 1cm but no firther than that.
Used the search but to no avail, any common problems?
Tim
Offline Jay
  • balding fat cvnt
Re: Dropping window
« Reply #1 on: 03 December 2007, 19:37 »
Electric or Manual winder?  Is there anything you do that makes it drop?
Offline CHRIS_MC
  • GHETTO GHOLFER
Re: Dropping window
« Reply #2 on: 03 December 2007, 19:42 »
i found that my driverside electric window regulator/motor was not working so i took it off stripped it, cleaned the rust off it put it back together........
also i found that the foamy guide bit wasnt sitting right, and the glass was sliding up the wrong side, corrected that and now its ok (although a bit slower than the passenger side)
this im happy about because my local VAG garage said just bin the motor & get a new one........ :rolleyes:
Offline T_J_G
Re: Dropping window
« Reply #3 on: 04 December 2007, 11:31 »
It's manual sorry :smiley:
Nothing I do makes it drop. May be the bumps in the road though.
Offline Jay
  • balding fat cvnt
Re: Dropping window
« Reply #4 on: 04 December 2007, 20:46 »
You removed your door cards and had a look inside? Maybe there is something loose. If it is only the drivers side, remove the door card from the passengers side to make sure it all looks in place(or vise-versa). If its both sides, well then I dunno :p get someone to take pics of what their window winders look like behind the door cards.
