Author Topic: Genuine R32 Headlights...  (Read 3633 times)
Offline northernlad
  • Ta biatche
« on: 30 November 2007, 21:11 »
I've bought some genuine r32 headlights..
it says i need a 12pin socket and mk4 only have 10 pin..
also does the r32 headlights only use one ballest?
cheers.
*** VAGSLAGS -> -> WWW.VAGSLAGS.COM
Offline Rhyso
Re: Genuine R32 Headlights...
« Reply #1 on: 30 November 2007, 21:18 »
you need to do a wiring modification
http://forums.vwvortex.com/zerothread?id=929027
Offline northernlad
  • Ta biatche
« Reply #2 on: 30 November 2007, 21:20 »
cheers,
on r32 headlights is there one ballast coz iv eonly got one on my left light...
Offline Rhyso
« Reply #3 on: 30 November 2007, 21:22 »
cheers,
afaik there should be on on each headlight  :undecided: its how they autolevel then i believe
Offline Ridg
  • TDI - Soot Happens!
« Reply #4 on: 30 November 2007, 21:47 »
cheers,
there are two ballasts one per light and they effectively convert the voltage from 12v to however many hundred volts are needed to strike the HID and maintain the current and sh1t
Offline northernlad
  • Ta biatche
« Reply #5 on: 30 November 2007, 22:53 »
well i only got one ballast on these 2003 model r32 headlights?
the right hand headlight (back of it) looks alot different from the left :S
Offline Ridg
« Reply #6 on: 01 December 2007, 11:36 »
do they both strike up? as they wont strike with out the ballast
i thought the bits on the back were the self levelling parts
which light is it that you've a problem with as i've got a spare drivers side
Offline richw911
Offline richw911
« Reply #8 on: 01 December 2007, 17:16 »
Did you fit your xenons yorself then "The ridge"?
Offline Rhyso
« Reply #9 on: 01 December 2007, 18:20 »
factory fitted; jammy git  :tongue:
