Author Topic: 8v still wont start  (Read 989 times)
Offline BIG D
8v still wont start
« on: 30 November 2007, 18:32 »
my problem is there isnt a live at the dizzy and i dont have a clue what it could be please help
Offline Agreeable Slick
  • Unit
Re: 8v still wont start
« Reply #1 on: 30 November 2007, 19:30 »
trace the center lead from the dizzy back to the ignition coil, and whip that off. If you can, get another one from a fellow golfer (that is proven to work) and stick it on yours. If it still doesn't start then it might be time to start tracing the wiring back from there.
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« Reply #2 on: 30 November 2007, 19:32 »
well i am under the impression that the spark comes from the ecu to the coil pack then to the dizzy. so check to coil if not try swapping the ecu. they are cheap enough off the gay bay. last one i bought was chipped too. (bonus!!)
Offline BIG D
« Reply #3 on: 30 November 2007, 19:47 »
there is a live at the coil but the middle wire on the hall sender should pulse from a live to an earth if i put a live to the dizzy it sparks but the wire goes to the ecu and the ignition module also could the ignition switch have anything to do with this
thanks
Offline woodlehouse
« Reply #4 on: 02 December 2007, 11:56 »
REMOVE IT ALL INC LOOM , SKIP IT & FIT SOMTHING BETTER LIKE AN ABF 16V OR VR6 OR 20VT :laugh:
Offline BIG D
« Reply #5 on: 02 December 2007, 12:21 »
Well i have thought about that but being 18 i dont think i could afford to get out of the garage but i would be nice to just look and admire
