Author Topic: *$^&ing Allen bolts!!  (Read 3844 times)
Offline Teletom
« on: 30 November 2007, 11:02 »
I have NEVER had an easy time with any allen bolts on my Golf - so far I've tried to tackle the alternator and the front disc bolts, all stuck fast and ended up going to a garage to get changed
I'm currently trying to do the rear discs, I've got a new allen key set that will fit on my socket wrench so I have a good tight purchase on it, I've also liberally applied WD40 to the area. Still it wont move, has anyone got any suggestions??
When the great scorer comes to write against your name, he marks not that you won or lost, but how you played the game - HST
Offline Mr Blue
Re: *$^&ing Allen bolts!!
« Reply #1 on: 30 November 2007, 11:11 »
wack a socket over the whole bolt. Works for me.
If not then get some heat on those bad boys :cool:
Offline jammac
« Reply #2 on: 30 November 2007, 11:23 »
use an impact wrench and more wd40! it will come out i promise
ITS A TRAP!
Offline Horney
« Reply #3 on: 30 November 2007, 11:38 »
Buy some "shock and unlock" from Halfords. Amazingly a halfords own product that actually works!
Nick
Offline Teletom
« Reply #4 on: 30 November 2007, 11:59 »
Cheers people, I got some things to try now! Going to work now, but I think it shall be an oily fingers weekend!
I've got an impact wrench but there's simply no way to get any swing on a hammer with the bolt I'm trying to attack.
thanks again
Offline Horney
« Reply #5 on: 30 November 2007, 12:04 »
I really recomend you pick up a can of this stuff. WD40 is not really the best stuff for stuck bolts, it's best for squeeking hinges!
Nick
Offline Agreeable Slick
  • Unit
« Reply #6 on: 30 November 2007, 12:24 »
Nick
You might find this stuff hard to come by, as i have never seen it at any of the stores i have been working at. However, there are two other things to try, one is called freeze release by loctite and the other is a penetrant spray can't remember who it is made by. They are both in the additives section, i.e. where the redex and all that sh!t is.
Instead of using a hammer on the wrench, just stick the wheels on full lock and then get an 24" breaker bar on there and they should come off no worries. :cool:
Offline dabill
« Reply #7 on: 30 November 2007, 13:25 »
scaffold bar on the end of the wrench, stand on the end, will come undone i promise you, unless you weigh nothing...
noble tuned - and still not fast enough!
Offline Gernster
« Reply #8 on: 30 November 2007, 13:43 »
youll sheer the bolt head off using a bl00dy scaffy bar!
Heat is you best bet, ask a plumber of you can borrow his blow torch.
Gernster - GTi-TD
Offline dabill
« Reply #9 on: 30 November 2007, 15:04 »
pffft dont worry yourself about sheering the head offf!!! sheesh!
get a bar on it!!! messing about with a heat gun or blow torch for 15 mins, or a 2 second job witha  bar!
