Author Topic: Catalytic convertor on a mk2?  (Read 5875 times)
Offline Mk2George
« on: 28 November 2007, 21:00 »
Did the Mk2 Golf ever have a catalytic convertor fitted??
Offline Dec
Re: Catalytic convertor on a mk2?
« Reply #1 on: 28 November 2007, 21:02 »
I think some did as ive been looking at some exhausts and it specifies ones without one :smiley: better check with someone though.
Offline edd16v
« Reply #2 on: 28 November 2007, 21:15 »
Yes my mk2 16v originally had a cat. Im not sure if the early ones did, mines a 1991 J reg.
Offline jettagolf
  • Mk2 Golf GTI
« Reply #3 on: 28 November 2007, 21:20 »
the really late ones did, late 91 and 92
Offline Agreeable Slick
  • Unit
« Reply #4 on: 28 November 2007, 22:05 »
cat laws only came into effect in 92 iirc.  :wink:
Offline Mk2George
« Reply #5 on: 28 November 2007, 22:26 »
Just got a 92 16v and theres a big box before the centre pipe, silencer or cat?
Offline Organisys
  • Old and Slow...
« Reply #6 on: 28 November 2007, 22:33 »
^^ Silencer.
Some Mk2s did have cats, not many in this country though.
Offline Dec
« Reply #7 on: 28 November 2007, 22:34 »
this is defo a stupid Q but what do they do? :embarassed: :embarassed:
Offline Mk2George
« Reply #8 on: 28 November 2007, 22:37 »
^^ Thought as much Organysis, i must admit it doesnt look anything like a cat :)
Blazing Storm
« Reply #9 on: 28 November 2007, 22:54 »
A catalytic converter is a device that uses a catalyst to convert three harmful compounds in car exhaust into harmless compounds.
The three harmful compounds are:
    * Hydrocarbons (in the form of unburned gasoline)
    * Carbon monoxide (formed by the combustion of gasoline)
    * Nitrogen oxides (created when the heat in the engine forces nitrogen in the air to combine with oxygen)
Carbon monoxide is a poison for any air-breathing animal. Nitrogen oxides lead to smog and acid rain, and hydrocarbons produce smog.
In a catalytic converter, the catalyst (in the form of platinum and palladium) is coated onto a ceramic honeycomb or ceramic beads that are housed in a muffler-like package attached to the exhaust pipe. The catalyst helps to convert carbon monoxide into carbon dioxide. It converts the hydrocarbons into carbon dioxide and water. It also converts the nitrogen oxides back into nitrogen and oxygen.
Reference: http://auto.howstuffworks.com/question66.htm
