Author Topic: STARTS UP FROM COLD WELL, BUT ONCE ENGINE IS WARM IT STALLS/TURNS OFF-HELP PLZ:(  (Read 1052 times)
Offline decronic
hi, :cool:
my golf 1.8 gti mk2 digifant starts up from cold well :smiley:, but once the engine is warm the car stalls/turns off :sad:.
But then starts up first time, but whitin 10 seconds turns off again. the warmer the engine gets the time it takes to turn off decreases?
thanks in advance for your replys.
Offline decronic
anyone ever had this problem? :huh:
Offline jamie_pyrite
In the last week or so since I filled up my tank at Sainsbury's, I've had major problems with my idle.
The car starts up ok but if I don't keep the revs at 1k for the first few minutes it drops so low it cuts out. Then when it's hot it'll idle at 650-700, even when warm.
Seems like this problem and my petrol are related so that may be why for you? If not, I'd like to know too :)
Offline decronic
thanks jamie, :cool: i wish it was as simple as the fuel :shocked:, someone on this board must have the same problem :undecided:
Offline fused
Might be ISV valve, stuck in cold position? I'd take a look at the ISV, check firstly that with the ignition on it buzz's/hum's not sure how to best discribe it! if not then it's probably shot, but you should clean it out once in a while, carb cleaner works well, it might just, maybe, only a remote possibility, bring it back to life if it has only just stopped! also look at the old blue temp sender on top of the coolant flange, go VW for this.
Good luck
Offline Organisys
  • Old and Slow...
1) Replace BLue Temp sender
2) Check for air leaks round the throttle body and on top of the rocker cover
3) Clean out the Idle stablisation valve
If this doesn't fix it - check the wiring and the switch on the underside of the throttle body that switches on closed throttle - tells the ecu to go into idle mode.
Offline decronic
thanks everyone--where is the rocker cover- i tried to find it but to meany things look like a flying saucer in the engine. :smiley:
as above, plus check out my digifant tuning guide :)
the rocker cover is the metal cover on the top of the engine, and the flying saucer is the round plastic thing on top of it with a hose to the throttle body.
