Author Topic: 2.0 16v (ABF) into MKII Digi 8v  (Read 6710 times)
Offline Horney
Re: 2.0 16v (ABF) into MKII Digi 8v
« Reply #10 on: 28 November 2007, 12:36 »
170bhp you say? That's gotta be propper quick, was he still running the standard digifant set up?
*Scurries off to see how uch an ABF will cost on eBay*
Nick
VeeDubGTI16v
« Reply #11 on: 28 November 2007, 13:01 »
generally it seems the abf's on kjet make 160-170 in a mk2 after a setup at stealth, i dunno what can be done to the digifants?
Offline Horney
« Reply #12 on: 28 November 2007, 13:25 »
Probably not as much but it appeals for it's plug and playness so should be reliable etc.
I'd be happy with 150 tbh, but 170 would be wicked!
Nick
« Reply #13 on: 28 November 2007, 13:44 »
yeah i did this to J_S' car, was a straightforward swap but wasn't as easy as the 2.0 bottom end I fitted to my 8v!
The loom will plug in IF you have a 90 spec car, but it isn't quite as simple as that, there are 1 or 2 wires that need swapping/splicing between the MK2 & MK3 engine loom.
You also have to spend a while binning all the crap from the MK3 loom that you dont need, lighting etc etc.  Best way is to pull the old MK2 loom out, keep the lighting part then work on the MK3 loom stripping it down, then compare what few plugs you have left to the MK2 looms, swapping/splicing wires where needed.
Best way to strip the MK3 loom is to start with the ECU loom, and bin EVERYTHING that isnt connected to it, if it aint running to/from the ECU ore one of the engine sensors you dont need it!  Main one to watch out for is the lambda probe plug, it has 1 wire to the ecu and earth/power wires to the fusebox you'll need to keep, and MAKE sure you get the diagnostics plug, and if its a post 96 get the key from the car along with the transponder ring from ignition surround, along with the control box and associated wiring.
Once you identify unneded wires, use my fusebox FAQ to treack down all the pins on the MK3 plugs, to double, double check you dont need them, then chopy chopy.
After that the hard part is over, engine will bolt straight in using MK2 mounts and mount brackets, keep your old gearbox unless it knackered or you plan to go for BIG power, and use a std MK2 16v manifold & downpipe for an easy life.  The OEM VW units are proven to flow very well :)
Offline Horney
« Reply #14 on: 28 November 2007, 13:56 »
What's the difference between pre and post 90 Digifant then as mines an 88?
Nick
« Reply #15 on: 28 November 2007, 14:01 »
the fusebox & car loom is the difference!  Not the end o the world you could identify said engine wires and splice them into your pre-90 loom.  Or you could do what I did on J_S' MK2 and completly rewire it to 90 spec standard :)
Offline Horney
« Reply #16 on: 28 November 2007, 14:11 »
I reckon this is the way to go then as on the shorter ratio 8v gearbox it should be a right screamer. Once I've sorted out some nice rims and tidied up the bodywork I'll have to start getting bits and bobs purchased for this!
Nick
Offline dubslug
« Reply #17 on: 28 November 2007, 16:25 »
sounds like 2l bottom ends cheaper and easier to me
1992 pearl grey 8v
Offline Horney
« Reply #18 on: 28 November 2007, 16:31 »
You don't like wiring do you mate? Looks easier if you ask me and certainly more bang per £.
Nick
« Reply #19 on: 28 November 2007, 16:34 »
nah 2.0 bottom is by fa rthe easiest option, unbolt head, bolt to 2.0 block, fit engine back in same eway it came out, job done ;)
