Author Topic: Wiper woe  (Read 2423 times)
Offline Peel
  • T4 campervan
Wiper woe
« on: 27 November 2007, 20:49 »
Swapped the wiper arms for new ones a few weeks back. Driver's side been unreliable ever since and now not moving. Nut turns with a spanner on it but will will neither tighten nor loosen, which of course means I can't get it off.
Oh, and it's raining.
What do I do boys?
Thanks.
Golf GTI: good enough as it is
Offline Ben Lessani
Re: Wiper woe
« Reply #1 on: 27 November 2007, 21:12 »
TIP #1...don't make the same mistake I did and shear the shaft 10mins before needing to travel 250miles in pouring rain
TIP #2...just shear the shaft, remove the two big 22mm nuts, drop the whole mech out, then pop the balljoint and the circlip retaining the shaft, and just replace it with a new one.
Re: Wiper woe
« Reply #2 on: 28 November 2007, 13:27 »
I had this, the reason is there are 2 shaft sizes on MK2s, the early shaft is smaller than the late one.  fit a late arm on an early shaft and you shear the stud and/or bugger up the threads like you just have!  The shaft size changed around 89ish, my 89 wiper arms wouldnt fit on my 90 spec GTI.
Offline Peel
  • T4 campervan
Re: Wiper woe
« Reply #3 on: 28 November 2007, 13:51 »
Fit a late arm on an early shaft and you shear the stud and/or bugger up the threads like you just have!  The shaft size changed around 89ish, my 89 wiper arms wouldnt fit on my 90 spec GTI.
That's what I've done then. Thanks.
I'll get some later shafts from GFS or similar and swap em over.
VeeDubGTI16v
Re: Wiper woe
« Reply #4 on: 28 November 2007, 14:44 »
is there any difference in the rear wiper arms?
Re: Wiper woe
« Reply #5 on: 28 November 2007, 15:16 »
nope afaik rears are the same.
VeeDubGTI16v
Re: Wiper woe
« Reply #6 on: 03 December 2007, 10:50 »
they are different! found out this weekend when replacing mine, my e reg has a smaller spline than the later golfs at the breakers
Re: Wiper woe
« Reply #7 on: 03 December 2007, 12:51 »
odd, my 89 with the small spline front wipers had the same sized spline at the back to my 90 gti!
Offline Mid_life_crisis
Re: Wiper woe
« Reply #8 on: 03 December 2007, 20:58 »
well at least you can get your wiper to work had car for four weeks now and still not had wiper working i think the wiper stalk is broken cos if i push it backwards only the screen wash work :embarassed:
VeeDubGTI16v
Re: Wiper woe
« Reply #9 on: 03 December 2007, 21:31 »
have you checked the wires going through the tailgate, top left. they have a habit of breaking behind the grommet?
