Author Topic: One for the Gearbox Experts.  (Read 3424 times)
Offline Horney
Re: One for the Gearbox Experts.
« Reply #10 on: 29 November 2007, 13:21 »
As far as I am aware the reverse lights have to work if fitted. If you don't have any it won't fail but if you do it will. I found this out when I had my old mini as I put 60's lights on the rear which did not have a reverse light built in when the original lamps on the car did. I thought I would have to fit a reverse lamp but the tester said that if the car doesn't have any he can't test them and reverse lights aren't a legal requirement.
Nick
R98 HUF
« Reply #11 on: 29 November 2007, 13:25 »
well mine were clearly fitted and not tested!!!!!!! i watched the guy dot he test and questioned him after....
quick search of google....
http://www.motors.freeuk.com/faq/motl.htm
Are reversing lights part of the MOT test?
The testing manual makes no reference to reversing lights and are not testable items as such, however you *could* be issued with a failure if they were illuminated all the time.
so if the internet is right they are not testable but if illuminated permanently you will fail.....
« Last Edit: 29 November 2007, 13:28 by R98 HUF »
« Reply #12 on: 29 November 2007, 13:29 »
nope completly not any part of the MOT, as I said earlier check the MOT testers manual, it aint in there.  The tester that failed your car was clearly a muppet who didnt know the rules ;)
Offline JC
  • Back in the North.
« Reply #13 on: 29 November 2007, 13:56 »
well  as my rear lights are smoked you cant tell that reverse lights are there  :laugh:
Jumped the connector yesterday and they do work, so just need to get some connectors and do the mod on the link RubJ's posted  :cool:
Offline JC
« Reply #14 on: 29 November 2007, 13:59 »
only adverse effects from an old gearbox would be:
1) its f**ked :grin: erm, its a recon box  :undecided:
2) gear ratios are pants erm, how would i tell ????
« Reply #15 on: 29 November 2007, 14:53 »
1) I meant 'if its f**ked' ;)
2) well does it feel nippy, or slow?
Offline JC
« Reply #16 on: 29 November 2007, 14:57 »
well  to me its nippy, even after my fireblade  :shocked:
but i do drive 2 corsa, both semi autos  :embarassed: :lipsrsealed:
« Reply #17 on: 29 November 2007, 15:50 »
tis all good then, ratio choice mostly come down to driver preference anyway, unless its really badly missmatched like fitting a diesel box on a 1.6 carby :grin:
Offline dubmaster77
  • actualy on the road!
« Reply #18 on: 29 November 2007, 23:24 »
Im an MOT TESTER!
K-Jet is my friend!
Offline JC
« Reply #19 on: 30 November 2007, 08:14 »
and the answer is ??????
