Author Topic: Golf not well, vag com. help  (Read 2823 times)
Offline MaXXeH
  • Golf MK5 GTI
« on: 24 November 2007, 13:53 »
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00000
5 Faults Found:
01249 - Fuel Injector for Cylinder 1 (N30)
            29-10 - Short to Ground - Intermittent
01250 - Fuel Injector for Cylinder 2 (N31)
01251 - Fuel Injector for Cylinder 3 (N32)
01252 - Fuel Injector for Cylinder 4 (N33)
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
            26-10 - Output Open - Intermittent
Readiness: N/A
Address 03: ABS Brakes
   Controller: 1J0 907 379 Q
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 01317
No fault code found.
Address 08: Auto HVAC
   Controller: 3B2 907 044 C
   Component: CLIMATRONIC     C 0.7.0
   Coding: 01000
   Shop #: WSC 01317
Skipping Address 15-Airbags
Address 17: Instruments
   Controller: 1J0 920 921 A
   Component: KOMBI+WEGFAHRS. BOO V28
   Coding: 05442
   Shop #: WSC 00000
   Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1626273
Address 19: CAN Gateway
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
Address 46: Central Conv.
   Controller: 1J0 959 799 AH
   Component: 4V Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 01317
1 Fault Found:
01135 - Interior Monitoring Sensors
            36-10 - Open Circuit - Intermittent
End   --------------------------------------------------------------------------------------------------
Offline boyob32
  • 1.8T
Re: Golf not well, vag com. help
« Reply #1 on: 28 November 2007, 08:55 »
hmmm....
Are you feeling the effect of problems with your injectors, as stated with the faults?
if all four are playing up could be something as simple as the coil pack....other possibilties too though!!
Offline MaXXeH
  • Golf MK5 GTI
« Reply #2 on: 28 November 2007, 13:05 »
the car drives fine, i cleared the codes but they come back after a 2min drive. also have othr errors :(
Offline ub7rm
« Reply #3 on: 28 November 2007, 13:24 »
Coil problems usually have missfire codes.
Have you checked the loom to the injectors for any sign of damage?
2020 BMW 128ti
2017 Golf GTD Estate
Offline MaXXeH
  • Golf MK5 GTI
« Reply #4 on: 28 November 2007, 18:34 »
i dont no where i am looking,  just seems odd that they are all doing it :sick:
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #5 on: 04 December 2007, 10:29 »
Offline MaXXeH
  • Golf MK5 GTI
« Reply #6 on: 05 December 2007, 22:32 »
yea dont have codes
Offline ub7rm
« Reply #7 on: 13 January 2008, 07:21 »
I know this post is a bit old but did the OP find a solution to this problem?  Reason I ask is is that I read the other day that fuel pump relay faults cause injector short to ground codes.......
2020 BMW 128ti
