Author Topic: Grr Alternator, can't disconnect the wires  (Read 1327 times)
Offline Ant
« on: 22 November 2007, 12:59 »
I've got an (almost) broken red wire from the alternator, which is meaning that I can't get enough charge to the battery.
However I tried to remove the nut holding the wire in, but instead the post is rotating instead.
Any ideas how I can get the nut off?
Offline peaky83
Re: Grr Alternator, can't disconnect the wires
« Reply #1 on: 22 November 2007, 13:19 »
WD40, failing that Heat it up?
Last resort crind the nut off and replace it, be careful to not damage the thread on the bolt, try cutting the nut with a junior hacksaw will take a while but should work. I'd cut it in 2 places so you end up with 2 halves...
Offline Dec
« Reply #2 on: 22 November 2007, 14:03 »
yea my dad took a blow torch to a bolt in my engine :laugh: was the one where you adjust the fan belt tension. Worked well as it was ceased on :sad:
Offline Agreeable Slick
  • Unit
« Reply #3 on: 22 November 2007, 17:46 »
either that or go and get a nut splitter, then just crack it off. so to speak.
Offline Horney
« Reply #4 on: 22 November 2007, 17:52 »
A good idea in theory but I can't help but think that taking a blow torch to your alternator wiring is going to cause extra problems in the long run.
Nick
Offline Dec
« Reply #5 on: 22 November 2007, 18:10 »
Nick
yea :undecided: worked for the area i was doing though :evil:
Offline peaky83
« Reply #6 on: 22 November 2007, 18:11 »
I wasn't meaning a blow torch... Fire... extreme heat... alternator... hmmmmm :undecided:
Offline Ben Lessani
« Reply #7 on: 22 November 2007, 18:43 »
Are you sure its the alternator mate? The alt usually doesn't have a screw post on it - its a crimp terminal, the starter solenoid has a copper bolt on it which is prone to seizing - and as a result will rotate - eventually making the car a pain in the ass to start.
Looking into the engine bay (from front), the alt is on the left, starter on the right.
Offline Ant
« Reply #8 on: 22 November 2007, 18:55 »
Yep, def the alt, have tried all day to sort out, no luck, going to the garage tomorrow, let them deal with it.
