Author Topic: Flickering lights  (Read 1426 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
Flickering lights
« on: 21 November 2007, 23:56 »
When my girlfriends Golf Driver is running at idle the headlamps dim, then brighten then dim until you give it some revs, even the dash lights do the same.......any ideas?
I know I have put a few posts up on this Golf lately, just we have been doing the bodyworks on her over the past few months since purchase, now up and running as bodyworks are all done the engine and clutch and churning out some little gremlins!
Offline vw-bob
Re: Flickering lights
« Reply #1 on: 21 November 2007, 23:58 »
this is weird as i noticed mine doing that the other day  :huh: i have no idea what it could be
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #2 on: 22 November 2007, 00:00 »
i got the same.. think tis voltage regulator/brushes related in the alternator..
little unit that plops out with 2 screws then replaces..
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline vw-bob
« Reply #3 on: 22 November 2007, 00:01 »
i also noticed my headlights pulsing the other day. i could see it on the car infront as we sat in traffic
Offline dubslug
« Reply #4 on: 22 November 2007, 10:02 »
check the condition of ur battery and also what voltage ur alternator is kicking out, sounds like its only lghtly charging till it gets to certain revs
1992 pearl grey 8v
Offline redders
  • 88 8V GTI, 3dr helios blue
« Reply #5 on: 25 November 2007, 21:51 »
beavis is spot on....happened to me, had the alternater checked out and new volt reg later all was well.
red
Offline monzablue16v
« Reply #6 on: 25 November 2007, 23:05 »
Mine woz me bad bass innit blud
Offline vw-bob
« Reply #7 on: 25 November 2007, 23:34 »
is this cleanable without taking the altenator off?
« Reply #8 on: 26 November 2007, 08:19 »
should e possible to ccess.. its 2x screws.. you replace it as its 2 flint blocks on a spring inside.. that wear down
Quote
