Author Topic: coolant temp sensor  (Read 1008 times)
Offline kurtangle
coolant temp sensor
« on: 21 November 2007, 22:24 »
hi where do i need to install my green coolant sensor i have read that  black 1s are no good and may need to swap but where does this sensor live cheers  :wink:
Offline Ridg
  • TDI - Soot Happens!
Re: coolant temp sensor
« Reply #1 on: 21 November 2007, 22:48 »
the sensor lives on the passenger side of the engine, about half way down the lump
it should be the only thing on the passenger side with an electrical connector coming out of it.
if you look at the engine from above then its pretty much under the feed from the air box
hope this helps
