Author Topic: Removing intake manifold  (Read 1444 times)
Offline seedym
« on: 20 November 2007, 12:15 »
I was trying to get my intake manifold off in order to fit a new 'O' ring, as per the instructions in the Pierburg 2E2 FAQ above. However, one of the six fiddly allen-head bolts had seized, and I've mashed the end of it trying to get it to turn. It still won't budge, there's no room to get a chisel on it or a dremmel to cut a groove. What can I do? I've wasted two weekends on it now, and I'm getting frustrated. Will the exhaust manifold come off easily enough to create a bit more space to get tools in (that ought to help get at the other really recessed bolt that I haven't even tried to get out yet). What sort of money would a garage charge to do this? My dad's getting a bit fed up of me always asking him for help and then getting nowhere!
Offline takethefifth
Re: Removing intake manifold
« Reply #1 on: 20 November 2007, 14:13 »
You drill a hole into the knackered screw head and then use an 'Easy out' or some equivalent reverse threaded remove tool.
http://search.ebay.co.uk/easy-out_W0QQcrlpZ1143946142Q5f10136QQfcclZ1QQfclZ4QQfnuZ1QQfsooZ2QQfsopZ32QQkeywordZeasyQ20outQQrprZ78
Offline seedym
« Reply #2 on: 20 November 2007, 14:32 »
there's no room to get a drill in behind it, that's the trouble!
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #3 on: 20 November 2007, 14:37 »
an you get in to file the sides and spanner it out?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
« Reply #4 on: 20 November 2007, 14:50 »
Ah and i guess the screwhead that's gone is one of the ones that prevents you from removing it so you can get the drill into it?
If so well that is a twit.
I'm not very familiar with the carby setup so hopefully someone else will have an idea of something else you could remove to get access.
Offline hobbiniho
« Reply #5 on: 21 November 2007, 10:33 »
as said above probably the best way is to flatten to sides and get a spanner on it just make sure you make the spanner a tight fit so it wont round off on you  :grin: :grin:
Offline meg1980
« Reply #6 on: 21 November 2007, 17:39 »
In the time you spent two weekends mucking around you could of taken the head off removed inlet manifold removed old stud,reasembled head and then refitted it job done.Good luck
i was told the 020 rod box was supposed to be a strong box,how wrong are they 5 and counting on my mk2. Hopefully the quaiffe box will last.
« Reply #7 on: 28 November 2007, 13:00 »
as above your only option is to have the head off.  lucky for you the carby has the 'toilet bowl' connection between the manifold & downpipe so its easy to split!  If it was a GTI with the 6 bolts you would be in for a world of hurt.
Try again with the allen tool, I thought one of my bolts had rounded but it turned out the tool wasnt seating fully due to rust & crap buildup, get in there with a screwdriver if you cvan and make sure you dig out all the crud!
Offline DogDay
« Reply #8 on: 28 November 2007, 17:32 »
I also went through the pain... on one of the middle bolts I rounded it out.. ended up finding a piece of hex bar - basically a long allen key that was about .2 mm oversize and hammered the bastard in as tight as a nun's chuff. worked for me.
 :wink:
I assume its one of the inner bolts & not the outers....?
as far as using an easy out - they have a nasty habit of shearing and making things worse :sad:
Good luck
Bow Chikka Wow Wow
« Reply #9 on: 28 November 2007, 17:33 »
on the one i thought id rounded i hammered a 13mm socket over the top, bloody pain int ass to do though
