Author Topic: mk4 2.0 8valve missfire  (Read 1075 times)
Offline Pete_gti
« on: 19 November 2007, 21:14 »
hi all can any one help me with my golf its a 1999 Treg 2.0 8 valve its on 75000 miles and has always been serviced on time and has neva missed a beat until know . The problem is as follow when driving and your in a hi gear and you say slow down for a round about but dont change down a gear and put your fut down its misses and stutters but its doesn't always happen i have put my scanner on it and cant get a fault code and the engine management light doesnt come on i have replaced fuel filter, coil. leads,plugs have removed and cleaned injectors but still happens i was thinking temp sensor but i thought someone might be able to shed some light on my nightmare
Peter
Offline Pete_gti
Re: mk4 2.0 8valve missfire
« Reply #1 on: 19 November 2007, 23:32 »
also i have fitted a new airflow meter this made no difference either
Peter
Offline rich7874lufc
« Reply #2 on: 25 July 2010, 16:53 »
Must be a common fault that mate mine is exactly the same and i cant cure it ive tried plugs ,leads coil pack and fuel filter and it solves it for a while but then comes back,any way ive asked a machanic and he reckons there might be a bit of crap or water in the fuel tank or the fuel lines thats getting threw so might be worth a tank drain
