Golf mk2
Buzzing noise from front left over 50mph
Topic: Buzzing noise from front left over 50mph (Read 1856 times)
Brother_J
mk2 gti 89
16 March 2004, 09:12 »
Ok here?s the problem I get a buzzing noise from the front left of the car (MkII gti G reg) when I get to about 50 mph and the faster I go the louder it gets. The noise stops when I turn left. Any ideas!
VeeDubGTI16v
Guest
Re:Buzzing noise from front left over 50mph
16 March 2004, 09:23 »
can you feel it through the steering wheel?
tallchap
GTI forum regular
16 March 2004, 10:17 »
Had a similar problem - turned out to be a loose w'screen trim, check it out...
Does it go away if you take the car out of gear and 'coast' along at speed?
Brother_J
mk2 gti 89
16 March 2004, 11:12 »
The noise stays if I push the clutch in. I haven't tried tacking it out of gear but I think it will still be there, I?ll try it. and let you know. As for feel it through the steering wheel a little yes.
Last Edit: 16 March 2004, 11:14 by Brother_J
free
Guest
16 March 2004, 12:16 »
could be the weel bearing, or the cv joint about to die
GavG60
Here all the time
keep my credit cards away from me please :-(
16 March 2004, 12:19 »
sounds like it could be the wheel bearing? you could try jacking the front up holding the front left road wheel top and bottom and giving it a wiggle to see if there's any movement...
Brother_J
mk2 gti 89
Reply #6 on:
16 March 2004, 12:21 »
That?s what i thought! But thought I?d get a second opinion. So the next question is where is there a good garage in the sevenoaks area, new to the area and have not had any time to check out the local garages yet.
Golf mk2
