Author Topic: head unit memory wont keep  (Read 7227 times)
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
Re: head unit memory wont keep
« Reply #20 on: 21 November 2007, 01:20 »
yeah, best thing to do is t run a multimeter and check wot power supply your getting...check which is permanent and which is supposedly ignition live and switch then accordingly. just elliminate any cables you dont need to power the head unit from the power supply block.speaker block isnt realy any concern so leav that as it is.
other reason for this is if you have had an aftermarket alarm fitted and the fitters have somewhat patched up cables with use of those behind the head unit...not the best way of doing things but i'v seen sum bodge jobs dun that way. if its the factory alarm and immobiliser...then that is very peculiar.
chek further down the original VW wiring loom to assure nothing has been compromised with any wires or patched elswhere! But get the ole meter on it n see wot readings you get!
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
Offline gribsymk3
« Reply #21 on: 21 November 2007, 20:53 »
i have a laserline alarm and have the same problem with loosing all the settings, the stereo comes on as it should when the keys turned but all the settings are lost, is it jut a case of swapping the yellow and red over so the red goes into yellow of the hu and yellow goes into the red of the hu??
Offline Ruji
« Reply #22 on: 21 November 2007, 22:33 »
dats the general rule of thumb in the event of powering up but resetting of memory at every start point of ignition!try it n see how u get on..one way to find out realy!goodluck with that!
Offline BobbyT
« Reply #23 on: 25 November 2007, 16:41 »
right i still have this fault and it must be down to the cliford, so to fix should i just run a cable from the bat to the head unit with an inline fuse?  :smiley:
Offline Ruji
« Reply #24 on: 26 November 2007, 01:11 »
So to clarify...u have used a voltmeter and have tested the lives for the radio!?
Do u get a constant live without ignition?? If so....then i dont see how wiring a new live from the battery will help....if you decide to try this anyway....all you need to do is assure you have a fuseholder in between somewhere to prevent any future shorting of the radio and locate the fuse holder somewhere accessible.
but if you're getting a LIVE without the key in the ignition, then that should assure that the radio holds its memory which should route in line to the yellow cable of the radio power lead! you could if you want wire both red and yellow to that LIVE cable which basically keeps the radio on even without ignition, but you just got to remember turn it off everytime or remove the face which is technically switched off without it!
Did u look further down the original VW wiring for the radio to see if it had been compromised in anyway? any scotchlocks or connectors attached anywhere that may be catering for an external source...i.e...your alarm?
wel, if you have tried everything else, then by all means try routing a new cable from battery..or even just trace a patched in lead from the fuse box battery LIVE...same thing realy! or if for a quick diagnosis...jus run a cable outside the car into the car door to the back of the radio just to test your headunit..if you find that method is effective, then u can decide to route that cable properly! keep us posted on how u get on!
Offline BobbyT
« Reply #25 on: 26 November 2007, 07:49 »
no there is no live, its seems when the key is out something cuts the power i am guessing the alarm is doing this. Will have a bash at a direct feed  :smiley:
