R32UK reply.
Hmmm let me think.
1. It just feels normal -
so does a dsg!2. Something to keep your left leg from being skinnier than your right one. -
that's why I left foot brake!3. Perfect starts everytime, if you know how.-
ONLY if you know how!4. Skip gears when and if its required.
Why would you want to skip gears when accellerating? The DSG can skip gears going down - never heard of kickdown
5. Better economy (yes this is true simply because i say so!! and the fact that you can read the road ahead better than the car can) -
If you say so it must be right!6. Dont have to waste time explaining to people that its manual.. when you really know it isnt -
No I boast that it is a DSG - twin clutch manual - without an archaic clutch pedal and just happens to have auto modes
7. no jerkiness below 10mph -
Neither has mine. Ive seen plenty of kangarooing manuals, usually when some numpty doesn't give it enough gas or gets the clutch wrong
8. no problems parking. -
Same here9. No need to switch between modes -
only EVERY gear!
10. No future problems.. or paddel problems -
only worn clutches, shagged gearboxes, Over revved engines from numpties selecting 2nd gear on motorways etc
i got more if you want -
For every one you have....I have more
Speedynz reply
It's faster (despite VW's claims) -
ONLY if you power shift and long term that is just going to knacker the car. A DSG can be used fully more of the time and the power is easier to accessIt's one of the best manual changes in any hot hatch and a delight to use -
I can't dispute that
It's always up to the the driver what gear you are in, not the intuition of a computer,
Can't dispute that either, although the DSG as you know does have a manual mode and when you combine that with the faster change times is very satifying tooThe manual never misses a gear - sometimes DSG doesn't respond at all, sometimes it chooses the wrong gear, -
I have heard of this, but I haven't had it yet in over 5000 miles. The manual may never miss a gear, but I bet you have
You always, always know which gear you are in, -
I don't need to know what gear I am in, I know by the rev counter, the engine pull and the sound of the engine if I am in the right gear - don't you?It doesn't break, -
bit of a broad comment this one. Maybe the DSG has some issues as it is a modern, complicated, state of the art piece of engineering - unlike the antiquated engineering of a manual gearbox
It's cheaper (much), -
yes, but you have to pay for perfection
It doesn't pause then lurch on initial take off, -
neither does mine! I suppose manual gearboxes or more precisely their users, never fluff takeoffs or stall on take off?
Launch control is always engaged -
I know where you are coming from with this one and I guess you are right as long as you select the traction control off too
You have a choice to heel and toe (and the pedals are absolutely perfect for this) -
ok, got me on this one :embarassed:
It's tactile, far more engaging and a wonderfully integral part of the car/driver interface, -
agreed, so is the DSG if you use it as a manual (which I do regularly)It's a real gearbox and not two tiny, tappy switches hidden somewhere between the steering wheel and control stalks, -
the DSG is TWO gearboxes spliced together in perfect harmony
If you've got fingers bigger than a childs you don't have to engage main beam and the rear wiper to fit the gear lever,
OKAY, so I have hit the main beam once before instead of the down shift paddle :embarassed:
but I'm used to it now
Was that two taps? or three? Oh noooooooooooo! -
was that third or first...oh my poor manual gearbox!I suppose we could bat on like this ad infinitum. I guess the only thing we can agree on is that we differ in our choice of preferred gearbox, which I respect and wouldn't have it any other way as it makes for great threads like this
