Author Topic: hot tunning coilovers  (Read 920 times)
Offline BobbyT
« on: 14 November 2007, 09:14 »
hi all, has anyone fitted these? i know there soooo cheap they must me poo but i am on a budget with the vr. anyone fitted them? :smiley:
Offline Paul86S2
Re: hot tunning coilovers
« Reply #1 on: 14 November 2007, 11:12 »
Yes, I have fitted them. They seem well made, fitted perfectly, and came with the rear bump stops. The downside is they are a bit harsh on the normal UK roads. I seem to remember in their adverts that they were about 25% stiffer (but could be wrong). They suited my needs for my trackcar project and are / were very good on the 2 trackdays I've done since fitting them.
I wouldn't like to say how they compare ride wise to other coilovers for the Golf because I haven't tried or ridden in any others with them fitted.
Paul
Offline bored_Welsh_lad
« Reply #2 on: 14 November 2007, 23:35 »
i have them and they are awesome, my only issue is they dont go low enough in the front with the helper spring in, i am going to remove the helper and see how she sits then, but i can honestly say they are awesome!!
1 point to note is to change your top mounts at the same time mate!!
they are so cheap ive just ordered an alf cage from them
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline remapped
  • If you are going through Hell, keep going
« Reply #3 on: 14 November 2007, 23:56 »
silly question but do i need to use spring compressors ?...... whit the coil overs kits ? would i need to compress the old shocks to get take of parts to be used for fitting ?
OEM(ish) G3GTi 8v5dr
« Reply #4 on: 15 November 2007, 00:01 »
when i do it i dont bother, i leave the car on the deck, undo the top nut and then when i jack it up in the air it takes the weight off the springs, but.... when you undo the two lower bolts you have to give the shock a bit of a knock to get it off the lower arm.
Thats how ive always done it though.. and you wont need them for the coilys...
there are two nuts to undo on the top mount though, i managed to get both mine off with an airgun but you might need them to get the nut off with the shock off the car.
Bumper Vents :D
