Author Topic: GOLF MK2 What are the Biggest alloy I can get???  (Read 2380 times)
Offline bulk66
  • Im broke an it aint a joke!!!!
Re: GOLF MK2 What are the Biggest alloy I can get???
« Reply #10 on: 14 November 2007, 10:05 »
Yea i think 17s just dont look quight right on a mk2 15s and 16s are cheaper to buy and tyres are cheaper why not look for some origanal Vw alloys and get em refurbed and then slam its arse on the deck. :grin:
Offline bulk66
« Reply #12 on: 14 November 2007, 10:31 »
As long as your off-set is right then theres no probs dude. :smiley:
Offline richardhammond
« Reply #13 on: 14 November 2007, 10:58 »
what off set do i need i was told 35?
Offline mk2mark
« Reply #14 on: 14 November 2007, 11:41 »
Yep, Bear in mind it's the offset and width that give you scrubbing, not the diameter. You could have 14" wheels that rub loads and 17" with none whatsoever. 6.5" wide and a 35mm offset is standard for a gti IIRC.
Offline dubsport
  • TDI POWAR!
« Reply #15 on: 14 November 2007, 11:51 »
17"s on a mk2 that isnt lowered is going to look like a monster truck  :huh:
Offline lewis1641
  • stuck in the 90's
« Reply #16 on: 14 November 2007, 12:25 »
i agree. if its standard height, stick to 15's. if you want to lower it do that before you fit the wheels. for your info i have a mk2 woth 60mm drop and i was running 6.5 x 17's for a bit. i thought it looked good but the ride was harsh. there are plenty of cheap tyres in 205/40/17 (have a look at mytyres.co.uk)
i also had some 6 x 15 tsw evo's on for a bit with 195/50/15 tyres. this was when the car had standard suspesion. the tyres were big enough to look good in the arches.
with a budget of £300 i'd get some lowering springs and a set of alloys off ebay.  if you take your time and trawl through all the wheels, rather than searching "golf alloys" you will find a bargain sooner or later.  my best find so far was a set of 19 inch mille miglia wheels and tyres off a freelander for £50 due to a terrible listing!
