Author Topic: engine cleaning  (Read 1356 times)
Offline gribsymk3
engine cleaning
« on: 11 November 2007, 21:45 »
im gunna give my engine and bay a good clean, im not using a pressure washer only a watering can for rinsing. can anyone give me advice on what electrical stuff needs covering??
Offline gribsymk3
Re: engine cleaning
« Reply #1 on: 11 November 2007, 23:01 »
anyone? :huh:
Offline Guy
Re: engine cleaning
« Reply #2 on: 11 November 2007, 23:12 »
cleaning section... cosmetics... there are threads in there on this
Offline Pete Taylor
Re: engine cleaning
« Reply #3 on: 12 November 2007, 12:00 »
You have to be brave to do this..
I've done it a few times with excellent results. Best time to do it is before cleaning the car. Lift up the bonnet and spray this stuff everywhere (apart from around the battery, dizzy, and coil)..
(Autoglym engine & machine cleaner)
Wash the rest of the car then go back to the engine bay when done, that will of given the cleaner plenty of time to soak in. Then get the jet spray on it on the lowest setting (sort of mist) and get off all the cleaner but avoid the same areas as mentioned above. I've done it several times with excellent results. Like I said though you have to be brave as anything electrical could easily break if you're not careful. I've not had any problems with the car not starting after as of yet but make sure you have a can of WD40 and VAG COM ready just incase..
Offline remapped
  • If you are going through Hell, keep going
Re: engine cleaning
« Reply #4 on: 12 November 2007, 13:11 »
Autoglym engine & machine cleaner every time  !!
just make sure the engine is cold !
OEM(ish) G3GTi 8v5dr
Offline gribsymk3
Re: engine cleaning
« Reply #5 on: 12 November 2007, 13:35 »
so cover coil and dizzy then? anythin else? :tongue:
Offline Pete Taylor
Re: engine cleaning
« Reply #6 on: 12 November 2007, 13:36 »
Doesn't smell too good going onto a hot radiator..
Offline remapped
Re: engine cleaning
« Reply #7 on: 12 November 2007, 14:33 »
the stuff costs a bit but worth it !
