Author Topic: dump valve and filter  (Read 1821 times)
Offline rambo25
« on: 11 November 2007, 14:00 »
whats the best dump valve and induction kit for my 1.8 gti turbo
« Last Edit: 11 November 2007, 17:52 by rambo25 »
Offline samy_1800_turbo
Re: dump valve and filter
« Reply #1 on: 11 November 2007, 21:43 »
i got a pipercross foam filter with a forge 007p diverter valve, you get a nice whoosh noise wid it not to loud so it dosnt sound like a chav car. :smiley:
Offline Holgate End
« Reply #2 on: 11 November 2007, 21:45 »
Does that valve not give you the 'blackpool lights' syndrome on your dashboard and poor response tho Samy?
« Reply #3 on: 11 November 2007, 21:58 »
dats the atmosphemic dump valve dat isnt very good for the car. iv got the forge replacement one which does the same job as the bosh standand valve but the forge can hold the higher boost better if you have a chipped car
Offline Jonnys07
  • GTi Anniversary 180bhp - Milltek Coming Soon!!
« Reply #4 on: 11 November 2007, 23:34 »
I just got my BMC CDA induction kit fitted today  :grin: Ok it increases fuel consumption but looks the part and gives off a gd roar. Pic below.........
Offline 1688bran
« Reply #5 on: 12 November 2007, 00:30 »
    i got a BMC CDA in my car too. lokin at ur pic . u hvnt got a little filter to put on the secondary air pump inlet pipe .i advise u put a filter cuz u be suckin all the dirt ,oil and water thru it .wont do ur engine any good ...
Offline Jonnys07
« Reply #6 on: 12 November 2007, 13:35 »
Sorry didnt realise that was taken whilst waiting for the filter to arrive. I fitted one about half an hour after the pic was taken. Well done for spotting it tho  :smiley:
Offline 1688bran
« Reply #7 on: 24 November 2007, 14:01 »
   where did u get the filter from ............
Offline Ashmond
  • Money, b!tches And Boost
« Reply #8 on: 24 November 2007, 15:22 »
I have got a cold air feed and a forge splitR valve, which gives you the dumping sound and still recircs some of the air back into the engine so it doesnt make your ECU fail!
Offline leeroy20vt
  • h reg mk2 gti
« Reply #9 on: 24 November 2007, 16:11 »
were did u get ur filter from and how much if u dont mind me asking and wat is the cold air filter
