Author Topic: Dyno  (Read 1975 times)
Fielder5757
Dyno
« on: 13 March 2004, 19:44 »
Just wonding, Would my car benifit from a Rolling road tune up before inters?? And if so what benifits can i expect?
Offline lewis
Re:Dyno
« Reply #1 on: 13 March 2004, 22:42 »
It?s a bit difficult to say really, what car do you drive?   I seem to remember it's a mk2 but is it mechanical or electronic injection? Have you made and modifications to your car as it might be cheaper and easier for you to get it krypton tuned. If you do get it on a rolling road make sure your car is read for it as it will defiantly be put through it's paces. Check your tyre pressure is correct, your coolant level is correct and your fan works. There?s probably a few other things you should consider, if you take a look at www.pumaracing.co.uk there is a section all about preparing for a roiling road session.
Offline GavG60
  • keep my credit cards away from me please :-(
Re:Dyno
« Reply #2 on: 15 March 2004, 09:25 »
If you've got a kjet injection, and live anywhere near south london/kent, I can point you in the direction of a top rolling road tuner  ;D
old guy at Sanspeed www.sanspeed.co.uk been racing for years, v.good on rolling road (got my mk2 16v to 136bhp at the wheel, K&N only mod)
Fielder5757
Re:Dyno
« Reply #3 on: 15 March 2004, 14:38 »
Its a mk2 CL, Ive got a new exhaust on it and ive changed the filters on my carb, Im just looking for more power, Any suggestions??
Veedubgt18v
Re:Dyno
« Reply #4 on: 15 March 2004, 14:55 »
isnt there a jet you can drill out on those to give more fule at the top end? i would just take it to a garage make them setup the carb
Offline lewis
Re:Dyno
« Reply #5 on: 16 March 2004, 12:22 »
If you do get your carb set up make sure the place you take it to know about you model of carb and have replacement jets and gaskets so there?s no messing around. You could change to a different carb to get more power and adjustability, I don't really know a lot about them as I've only just bought my first a set of twin Webber 40's to go on my MK1. There are several going on Ebay at the moment but you will need to buy/make an intake manifold to suit your head which isn?t as hard as it sounds (I will have a pattern for one soon). You will need to get a good air flow to them as well as I guess you have a counter flow head, your linkages will need changing to. I think this will be a fairly cheap way to get a good power increase if you can get the carbs cheap. Have you swapped your cam to a GTi one as this will give you more valve lift and help improve your air flow to match the increase in fuel you will get from a set of twin carbs.I think the cams will only work if you have one of the larger CL engines but I?m not sure as I?ve never done it but I would have thought someone on here would know about this mod. Hope that gives you something to think about and have a look on the web for more carb info. The web site I mentioned earlier has something about jet set up?s and links to other web sites about carbs.
