Author Topic: water leak  (Read 1104 times)
Offline b300y
water leak
« on: 10 November 2007, 21:37 »
hi i got in my car this morning and i had a puddle of water in the drivers footwell plz help
once a dub always a dub
Offline nunny
Re: water leak
« Reply #1 on: 10 November 2007, 23:38 »
 :laugh: mines was like the titanic for a while! check all the rubber seals etc.....
Offline 8vRicey
  • Silver Mettalic 8v GTI
Re: water leak
« Reply #2 on: 11 November 2007, 09:42 »
door membranes, i bet ya !!  :wink:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
Offline Village Idiots
Re: water leak
« Reply #3 on: 12 November 2007, 08:37 »
Does it have a sunroof? The drainage tubes from the sunroof surrounds can block. Open the sunroof and see if you can poke something flexible (old speedo cable is favourite) down them.
Does parking on a slope (even slight) make a difference? I have a car which I always park downhill if there's any chance of rain. Another is the reverse, I always park it facing up!
Offline gibby
Re: water leak
« Reply #4 on: 12 November 2007, 12:01 »
Nail on the head. :wink: Had to do it myself and make some new membranes. To fully resolve your issue read this article. :wink:
http://www.matey-matey.com/leak_prevention.shtml
......now officially dubless.
Offline b300y
Re: water leak
« Reply #5 on: 13 November 2007, 11:43 »
were are the door membranes then cause the water seems to colects in the fusebox cover
Offline gibby
Re: water leak
« Reply #6 on: 13 November 2007, 14:51 »
Door membranes are behind the door cards. If water is coming in from the fuse box then it's likely to be loads of cr@p in the scuttle drains down the side of the inner wing causing water to build up in the scuttle. If so remove the gunk out of the drains.
Offline b300y
Re: water leak
« Reply #7 on: 14 November 2007, 11:38 »
hi again i had a look round the door seal and in the  corner was a big hole rotten in the boddy woork so ill get that repaired post some pics on hear of it and hope that sorts the problem
