Author Topic: How do i remove the mk4 rear doorcards? (3dr)  (Read 3909 times)
Offline strachan10
« on: 09 November 2007, 11:06 »
Hi guys,
Fitting speakers in the rear of my car and i cant for the life of me figure how to removed the rear door cards without damaging them. Can someone help please?
much appreciated :wink:
Scott
Offline strachan10
Re: How do i remove the mk4 rear doorcards? (3dr)
« Reply #1 on: 09 November 2007, 13:05 »
any1??
Offline Rhyso
Offline strachan10
« Reply #3 on: 09 November 2007, 14:23 »
it would have been perfect by i need help for a 3 dr model  :sad:
Offline Rhyso
« Reply #4 on: 09 November 2007, 15:36 »
bugger; thought it did cover it  :sad:
have a look through the below; see it if covers it  :undecided:
http://forums.vwvortex.com/zerothread?id=1835863&postid=18980425#18980425
Offline dub fatha
  • one of my finest creations ;0)
« Reply #5 on: 10 November 2007, 00:00 »
hiya mate
as far as i remember,
you will have to remove the lower parts of the back seat,
there are trim clips on the sides and bottom of the door cards, which are best to remove with a trim tool, as they are prone to break if you try to yank the door cards off.
once the sides and bottoms of the door cards have come adrift from the car, you will need to move the card in an upwards direction, as there are metal clips that hold the top of the cards secure to the bottom of the window.
hope this helps,
if you have any more probs, pm me and i will try to help,
regards
dub fatha
Offline 1688bran
« Reply #6 on: 11 November 2007, 02:32 »
Hi guys,
Scott
      to remove the rear door card ,u need take off both side of the plastic which hold the parcel self , then u need to take the back seats out .the bottom part of the seat is really easy just 2 metal pins holdin it.but the top part of the seat is abit hard , the side near the door card u just unslot it then the another side u jus give it a good shake ,it should come off . then the final part to remove the dor card u just lift it up but be gentle cuz there is a connection that connect the speakers ....
Offline strachan10
« Reply #7 on: 12 November 2007, 10:35 »
I just slid the wire up the gap between the doorcard and the plastic bit underneath and broke off the speaker cover.
wire up the new speaker and screwed it in. As my car is only a 1.4 model there were no speakers to remove so there was no real need to remove the rear door cards as i had no revits to drill out.
Thanks for all your help tho guys  :wink:
