Author Topic: hmmmmmmmmmm  (Read 2530 times)
Offline Thom89
  • Looking for an "Icebreaker"
Re: hmmmmmmmmmm
« Reply #10 on: 08 November 2007, 00:48 »
Simple solution... just roll the car onto 2 blocks of wood per side, lifting the car high enough to get the jack under...
Tom
Offline takethefifth
Re: hmmmmmmmmmm
« Reply #11 on: 08 November 2007, 18:44 »
You need a bigger jack!  :laugh:
VeeDubGTI16v
Re: hmmmmmmmmmm
« Reply #12 on: 08 November 2007, 18:47 »
how high is the sill when the jacks up all the way? somethings not right!
Offline dubsport
  • TDI POWAR!
Re: hmmmmmmmmmm
« Reply #13 on: 08 November 2007, 20:11 »
if i get pics and measurements for you tomorrow will that be ok ?
Leon R
Re: hmmmmmmmmmm
« Reply #14 on: 08 November 2007, 20:36 »
Anyone else found the scissor jack a bit of a death trap?! I use a normal trolley jack and that works absolutely fine. My friends VR lowered 60mm also was ok with it.
VeeDubGTI16v
Re: hmmmmmmmmmm
« Reply #15 on: 08 November 2007, 20:50 »
just approx to see if its lower than when the wheel is supposed to lift, either your jacks f**ked or your suspension is!
Re: hmmmmmmmmmm
« Reply #16 on: 08 November 2007, 22:56 »
It could be that the jack arm doesn't go high enough, my mate has one that is pretty damn useless like that, gave me the same problem. I've got a reasonable size one from Halfords now and it's fine.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: hmmmmmmmmmm
« Reply #17 on: 09 November 2007, 08:36 »
Scissor jacks are ok if used correctly. No more or less dangerous than the average bottle jack. Just don't rely on it if you intend to get under the car. The same for any jack.
Offline Philpy
Re: hmmmmmmmmmm
« Reply #18 on: 09 November 2007, 08:45 »
Tom
Dont think uve read his problem right....
Anyway as said I think ure jack is fu*ked
Offline dubsport
  • TDI POWAR!
Re: hmmmmmmmmmm
« Reply #19 on: 09 November 2007, 14:22 »
thanks for the replies, all sorted now :wink:
