Author Topic: Suspension Caps  (Read 1360 times)
Offline brisdriver
Suspension Caps
« on: 06 November 2007, 16:11 »
Hey just got some through the post today from venom motorsports, anyone using them, on the part of their page in golf plus its says easy to fit, but after ringing them to find out how to do it, it seems i have to take the struts completly off etc, and i need the tool to keep the springs compressed etc, not as easy as it first sounded
Any Help, advice or anything greatly appreciated
<a href="http://photobucket.com" target="_blank"><img src="http://i215.photobucket.com/albums/cc311/brisdriver/30-10-07_1419.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a><a href="http://photobucket.com" target="_blank"><img src="http://i215.photobucket.com/albums/cc311/brisdriver/06-11-07_1537.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Offline boneybradley
  • Back in a Mk3...
Re: Suspension Caps
« Reply #1 on: 06 November 2007, 16:25 »
yeah struts needs to come off and springs needs to be compressed as your replacing the cap that fits on the top of this!! when they say easy i think it means as easy as replacing a spring (which with the correct tools is simple..without a nightmare!)
Offline bunter
Re: Suspension Caps
« Reply #2 on: 06 November 2007, 16:33 »
should be a case of 3 bolts, one on the strut top which also has an allen nut that has to be held and 2 bolts on the lower end and the struts off, then use spring clamps to hold the springs in place and then it reasonably easy, just remember what order stuff comes off in and dont forget to mark the lower bolts or youl need youre tracking doing again.
hope that helps a little :)
Offline Horney
Re: Suspension Caps
« Reply #3 on: 06 November 2007, 16:41 »
should be a case of 3 bolts, one on the strut top which also has an allen nut that has to be held and 2 bolts on the lower end and the struts off, then use spring clamps to hold the springs in place and then it reasonably easy, just remember what order stuff comes off in and dont forget to mark the lower bolts or youl need youre camber doing again.
A little edit above. Also I think you need the special VW tool for the slotted nut (Or a rubber mallet and screwdriver!)
Nick
Offline bunter
Re: Suspension Caps
« Reply #4 on: 06 November 2007, 17:02 »
Nick
lol i cant be expected to remember everything, im an armchair mechanic :D
Offline brisdriver
Re: Suspension Caps
« Reply #5 on: 06 November 2007, 17:21 »
cheers everyone, I'll let you know how it goes probably going to do it on friday I think!!!
