Author Topic: Little pipe on airbox?  (Read 1513 times)
Offline Horney
« on: 06 November 2007, 10:00 »
What does the little pip from the bottom of the airbox to the top of the airbox do? Mine has at somepoint got caught in the belts and broken!
Nick
Offline tobz.
Re: Little pipe on airbox?
« Reply #1 on: 06 November 2007, 10:44 »
Sounds like the vacuum pipe that controls the hot/cold airfeed flap, you might wanna replace it now the mornings are getting so much colder.
You got any pics of your dad's split ?
Offline Horney
« Reply #2 on: 06 November 2007, 10:47 »
Ah OK, best get down the scrappie this weekend then!
Nick
Offline Organisys
  • Old and Slow...
« Reply #3 on: 06 November 2007, 12:39 »
Rip it all out Nick, I junked all mine years ago and the car runs fine, even when it's frosty. I just doesn't get cold enough in this country to worry about it.
Offline mk2mark
« Reply #4 on: 06 November 2007, 14:37 »
Yeah I think they're only supposed to be useful when you're talking russian winter cold!
Offline jammac
« Reply #5 on: 07 November 2007, 09:11 »
really? what about the one that goes from the top of the air box to............... the throttle body? i think? that one has to stay? no?
ITS A TRAP!
Offline seedym
« Reply #6 on: 07 November 2007, 10:27 »
I spent last Saturday re-connecting several of the vacuum hoses that, due to what must surely have been real botched jobs by various mechanics the car's been to over the years, were either disconnected or missing entirely. The car is running a heck of a lot better as a result, especially when cold. So my advice to you is to keep them all, and make sure they're all connected as they should be, 'cos they certainly do make a difference. There are diagrams on vagcat.com which are helpful, 'cos there's nothing in Haynes that I've ever been able to find.
Offline Organisys
  • Old and Slow...
« Reply #7 on: 07 November 2007, 12:21 »
Basically just make sure that if you remove them you don't have any vacuum leaks at the throttle body thats all. Plug any holes!
 :smiley:
« Reply #8 on: 09 November 2007, 17:16 »
if its a GTI, the vacuum connection and warm air feed pipe to the exhaust manifold shroud is there to make the engine warm up faster, nothing more.  If you do take it all off, make sure you block off the thin vacuum hose otherwise you'll end up with a vacuum leak :)
If its a carbed engine, it stops the carb icing up and stalling the engine, so fix it ;)
Offline dubslug
« Reply #9 on: 09 November 2007, 17:22 »
his is gti
1992 pearl grey 8v
