Author Topic: tyre pressures  (Read 1739 times)
Offline Morgs
tyre pressures
« on: 05 November 2007, 13:29 »
Could anyone tell me the correct tyre pressures for a mk4 golf gti 1999 please.
guidence of 1,9 bar seems a little flat to me.
thanks
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: tyre pressures
« Reply #1 on: 05 November 2007, 13:41 »
What size tyres you got on?
If they're 205 55 16's, then the factory/manual figures are 2.1 BAR at the front & 1.9 at the rear.  (Reduces understeer) :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Ridg
  • TDI - Soot Happens!
Re: tyre pressures
« Reply #2 on: 05 November 2007, 13:42 »
1.9 is right, the correct figure is actually on the inside of the fuel cap, which should be specific eg if you've got factory fit 14" or 18" rims
Re: tyre pressures
« Reply #3 on: 05 November 2007, 13:45 »
For the rears only!!!  :wink:
