Golf mk2
a bit spluttery
Topic: a bit spluttery (Read 894 times)
richard s
a bit spluttery
02 November 2007, 21:45 »
on my way home from work my car (89 8v gti pb) just seemed to get a bit choked up and spluttery it was running fine then i was sat in a bit of traffic oil temp was at 98 and then when i was moving i felt it happen and it ran like sh!t
there is a steep hill i turn up and it normally pulls fine in 2nd but tonight i had to drop down to 1st after about 10 feet and i could feel it holding back through the revs
all ideas and theorys as to what is wrong greatfully recieved cheers
Stu.750
MMMMMMM Rust my favourite
Re: a bit spluttery
02 November 2007, 21:48 »
How low on fuel was it ? might have dragged some crap up from the bottom of the tank ?
richard s
Re: a bit spluttery
02 November 2007, 21:52 »
half a tank mate but is returning 16.5 miles to gallon
OakeyDoak16v
Re: a bit spluttery
02 November 2007, 21:58 »
Bit low that init?
fused
Here all the time
Re: a bit spluttery
02 November 2007, 22:08 »
If you suspect the fuel, don't forget the fuel filter!! Mine was manky :embarassed:
richard s
Re: a bit spluttery
04 November 2007, 21:49 »
all i know is that it does not do it all the time
so where is the fuel filter as i may as well change it and see what happens
fused
Here all the time
Re: a bit spluttery
Reply #6 on:
04 November 2007, 23:14 »
should be a silvery looking large bake bean can (lines in/out at each end) under the rear of the car next to the main fuel pump, becareful when undoing the fuel lines as they are probably under high pressure!
takethefifth
Re: a bit spluttery
Reply #7 on:
08 November 2007, 18:29 »
How spluttery? Running on 3 cylinders spluttery? Could be an intermittent or weak spark somewhere.
www.tt5th.co.uk
Golf mk2
a bit spluttery
