Author Topic: 1.8t Actuator upgrade...  (Read 5106 times)
Offline richw911
« on: 02 November 2007, 20:04 »
What does the actuator actually do?? Is it worth upgrading to a forge one?? Any got a forge one? 1.8T BTW.
 Help as always would be good.  :smiley:
« Last Edit: 02 November 2007, 20:20 by richw911 »
Offline richw911
Re: 1.8t Actuator upgrade...
« Reply #1 on: 03 November 2007, 22:21 »
Nobody know?? What not even you rhyso??!!   :undecided:  :grin:  :grin:  :grin:
Offline Rhyso
« Reply #2 on: 03 November 2007, 22:43 »
cheeky sod  :tongue:  try using the search facility like  :rolleyes:
also check out this website:
http://www.forgemotorsport.co.uk/
i believe its worth upgrading as i think it helps maintain boost for longer  :undecided: and it not prone to failure.  also you can upgrade the spring to take into account a remap
Offline richw911
« Reply #3 on: 03 November 2007, 22:51 »
 :grin: I have googled it but wasnt very helpful. Thanks for that. Will have to make it one of the next few mods i fancy...
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 03 November 2007, 23:07 »
Bit of pointless bling in my eyes. The KKK turbo on your car already has an adjustable actuator rod. The only advantage of the forge item is the choice of spring weights, but again I don't see the point when the stock item is already more than capable of handling all the boost the wheezy borg warner unit can throw at it. Could be a good replacement item if yours ever breaks though.
