Author Topic: Idle Screw Won't Go back In  (Read 1160 times)
Offline Conker
« on: 02 November 2007, 17:25 »
Can't believe I'm posting this...  :embarassed:
Working on my 1991 16v... I removed the idle screw to clean it and now when I go to put it back in, it will only wind in four or five turns and is very tight - When I took it out, I could do it by hand, now I need a screwdriver  !!
All I did was clean it with carb cleaner and then squirt a generous amount into the screw hole. I don't think im cross-threading it
Advice and abuse both equally welcome (so long as theres some advice mixed in  :undecided: )
Offline mattkh
Re: Idle Screw Won't Go back In
« Reply #1 on: 02 November 2007, 17:33 »
Hi
can you see anything wrong in the hole.
I would not worry. The main thing is does it allow you to change the idle when you turn it.
Offline Conker
« Reply #2 on: 03 November 2007, 01:54 »
So how tight are peoples idle screws?  Perhaps there was loads of oily gunk in there and as I've cleaned it out perhaps thats why it feels so tight - I used to be able to undo it by hand.
Anyone?
VeeDubGTI16v
« Reply #3 on: 03 November 2007, 10:04 »
it should be finger tight!
Leon R
« Reply #4 on: 04 November 2007, 12:59 »
Is the seal on the screw ok? Maybe put some lube on it and try again.
Offline Conker
« Reply #5 on: 05 November 2007, 11:48 »
The screw doesn't work anymore - it has no effect on changing the idle at all, even though it more or less screws all the way in!?!   :cry:
Any ideas?  Is it just the rubber grommet around the screw?
VeeDubGTI16v
« Reply #6 on: 05 November 2007, 13:57 »
possibly, have you got it screwng in ok now? give the o ring a bit of grease, it might help it seal
« Reply #7 on: 09 November 2007, 16:59 »
just an o-ring round the screw.  sounds like you need a new one, bad news is they're expensive from VW! you can get a set of o'rings from chav-fords, with a bit of trial & error you'll find one that fits.
