Author Topic: THROTTLE POSITION SENSOR????VAG.COM  (Read 7461 times)
kells
« on: 01 November 2007, 17:53 »
Yo people
got my Vag.com lead today, and even tho the car is now fixed i thought id still give it a whirl, came up with this as fault code 00518, throttle position sensor  34-10 - no elaberation available- intermittant
what the hell's all that mean
anyone know?
car is running sweet btw
Offline boneybradley
  • Back in a Mk3...
Re: THROTTLE POSITION SENSOR????VAG.COM
« Reply #1 on: 01 November 2007, 18:31 »
this might help??
00518 P0121 Throttle Position Sensor - Signal Out of Range (G69) Also check for loose ECM
power relay.
and this
Starting in 1996 on OBD-II vehicles, Volkswagen began using an electric throttle control module to control the throttle plate. This throttle control module contains an electric motor that actually moves the throttle plate and two potentiometers that monitor throttle plate position and requested throttle position.
The throttle controller is synchronized to the powertrain control module (PCM) electronically. This matching process allows the PCM to memorize the closed throttle, wide-open throttle and pre-start throttle positions.
If power is lost to the PCM or throttle controller for any reason (disconnecting the battery is the most common reason), the synchronization between the PCM and throttle controller is erased!
This synchronization is known as the "Basic Setting." As hard as it may be to believe, basic settings are stored in volatile memory and are erased whenever power is lost from the PCM or throttle controller.try the disconnect battery for 5 minutes thing first and see if it comes back..
« Last Edit: 01 November 2007, 18:38 by boneybradley »
kells
« Reply #2 on: 01 November 2007, 18:37 »
blimey...
thats a mad read, i take it mine dont refere to most of that tho as it is a 1993 year??
do you know why it would come up as a fault on Vag.com, all the relays in the fuse box are secure..
  • Back in a Mk3...
« Reply #3 on: 01 November 2007, 18:40 »
try and disconnect the battery for 5 mins to reset car in basic setting mode and scan again... that was on an american site and is possibly only half true about year etc!!
kells
« Reply #4 on: 01 November 2007, 18:44 »
will try that and re scan :)
bloody yanks :cool:
  • Back in a Mk3...
« Reply #5 on: 01 November 2007, 18:51 »
hey kells next time your round my way (with your vag-com)...
give us a bell as mine was last scanned 2 years ago!! :wink:
kells
« Reply #6 on: 01 November 2007, 19:02 »
aye defo, not sure when im over their again as i have a really big club night event this month which im busy on but wont be too long anyhow so ill let you know, Not sure where u are in selby...dont say on here but are u near the town centre?
i got a crack copy on disc and ordered a speacial lead that fits the diog port, although i had to get an extra lead also to convert the lead further as my diog post is the old style
between this and my next door neighbour who is a technician at VW dealer in Leeds i cant go far wrong hehe....loving the Vag.com tho
  • Back in a Mk3...
« Reply #7 on: 01 November 2007, 19:49 »
yeah i live more or less town center... will be intersting to see what codes come up!!
kells
« Reply #8 on: 01 November 2007, 19:53 »
yeah thats what i though too haha  hence this post  :laugh:
  • Back in a Mk3...
« Reply #9 on: 01 November 2007, 19:57 »
well it did have a code read and new relay's, air mass meter and crank sensor when i bought it may 2006 and has run good since..only fault that did show since was my abs light came on sometimes due to iffy rear calipers (sorted with new discs tho!)
