Author Topic: Oil on the Flywheel  (Read 1604 times)
Offline Zayd
Oil on the Flywheel
« on: 01 November 2007, 11:47 »
When changing my clutch the mechanic found some oil on the flywheel.  He said that is looks fine but is asking me if I want to still change it.  He also says that apparantly the flywheels have oil inside them.
Does the oil indicate that the flywheel is knackered and needs replacing.
Turbocharged and liking it...
Offline MaXXeH
  • Golf MK5 GTI
Re: Oil on the Flywheel
« Reply #1 on: 01 November 2007, 12:54 »
when there is oil on the fly it will make it slip.  you just replace it.  You can clean it but it is never the same.
Offline gsn1978
« Reply #2 on: 01 November 2007, 13:02 »
clean it in a parifin de-greese bath will be fine, id have him check the crank shaft oil seal, that my be leaking a bit...... i wouldnt replace the fly wheel if its just got oil on it......
Cheers, George.... 1.8 GTIt and loving it!!
Offline Zayd
« Reply #3 on: 03 November 2007, 00:15 »
I got both the flywheel and clutch replaced at a total cost of £470 including labour.  He showed me the oil leakage and it was just coming from inside the flywheel.  It was just seeping out so I didn't suspect oil coming from anywhere else.
The car's driving great now, biting point is low and acceleration perfect.
