Author Topic: What engine oil?? MK3 GTi 16v w/ 73k  (Read 4415 times)
ShoCk
« on: 01 November 2007, 08:30 »
As the title really ...
What engine oil should I or would you recommend I use in my MK3 2.0 GTi 16v ... its at 73k miles and will be the FIRST service that has been done on the car since ive owned it.
Ive also bought Wynns Engine Flush & Petrol Additive both for under a tenner off ebay just for a piece of mind when the oil change is carried out.
Offline AlanD
  • MK5 2.0T 16v
Re: What engine oil?? MK3 GTi 16v w/ 73k
« Reply #1 on: 01 November 2007, 09:42 »
Well, seeing as no one as replied I might aswell add something.
Not sure how relevant this is but my 2.0 8v uses 5w-40 (fully synthetic). For the price of a few quid more your better off gettting the fully synthetic 5w stuff over the 10w (not fully synthetic lol) which you can also use.
ShoCk
« Reply #2 on: 01 November 2007, 13:46 »
Thanks for replying.
Any one else?
Offline AlanD
  • MK5 2.0T 16v
« Reply #3 on: 01 November 2007, 14:06 »
lol looks like no one else uses oil . . .
ShoCk
« Reply #4 on: 01 November 2007, 18:00 »
Doesnt matter, got more help on ClubGTi ... decided to go with 5w/40 Fully Synthetic oil by Millers.
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 01 November 2007, 18:03 »
I use 10/40 valvolene semi.... not really worth using fully synthetic on an older engine unless its had it most its life!
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 01 November 2007, 19:40 »
Similar stuff to mine then, I use the Castrol stuff and have no querks with it!
Offline Pete Taylor
« Reply #7 on: 02 November 2007, 11:19 »
Regards to the throttle body problem...
It is not motor powered. There is a sensor in there which detects the angle of the inlet 'flap'. If the signal is out of range it could be because of a broken sensor, a dirty sensor, or a clogged up throttle body which prevents the flap working within normal variants. The start angle should be 7 degrees. If the flap is not allowed to close to this 7 degrees then it will be signalling out of range. For it to actually throw up a fault code for it though i'd say it's the sensor knackered. For to be intermittent makes me believe even more that the sensor is broken. If you've been playing around adjusting the throttle cable  this could also cause this
