Author Topic: top speed problem, maf??  (Read 3216 times)
Offline arnoldlog1
« on: 30 October 2007, 18:33 »
i've got a gt tdi 130(2002), it's great had it a couple of years now love it, but i've noticed i seem to have a top end speed problem. when i first had my car my car would accelerate really well to about 120mph, (on a private road of course officer!) but now i get to about 100mph and i really struggle to get it up any higher. I've got no other issues with the car my mpg is great, i average 50 ish, no fault codes.
any ideas? i was thinking could be maf but i though i would see a difference in every gear, and i can't, thought it might be wheel alignment but i get no vibration from the steering wheel, and i get even tyre wear.
any ideas????
Offline Rhyso
Re: top speed problem, maf??
« Reply #1 on: 30 October 2007, 19:48 »
when was it last serviced?
dodgy MAF normally results in worsening MPG; does it feel flat at any point in the rev range?
have you checked for air leaks etc and you could be loosing pressure albeit in tiny amounts
Offline arnoldlog1
« Reply #2 on: 30 October 2007, 20:20 »
no thats what i can't work out it's not flat at all, it revs really well no flat spots. mpg is fine if anything getting better mpg now(maybe i don't drive it as hard as when i first had it).
it was last serviced 3.5k ago by my local vw specialist.
had a check round no signs of any air leaks.
Offline caddy vantastic
« Reply #3 on: 31 October 2007, 13:47 »
Possible Map sensor fault. That causes the same effects you are having.
To much going on to list all the work
Offline arnoldlog1
« Reply #4 on: 31 October 2007, 20:46 »
can anyone explain what a map sensor is? and more importantly what it does?
Offline Rhyso
« Reply #5 on: 31 October 2007, 20:49 »
